Oil Leak Problem 3.1L engine #252297 05/08/03 07:55 PM
MattGold Offline OP
So far the biggest source of oil on my driveway is the distributor. I can see the oil running down the back of the bell housing from the top. The valve cover gaskets look fine.
I got a replacement gasket for the distributor, but I have no idea where it goes? At his point I'm wondering whether RTV will work?
Matt
92' Rodeo with a lot of DOR parts
Re: Oil Leak Problem 3.1L engine #252298 05/08/03 08:53 PM
Check and replace the O-ring on the distrubutor shaft first. It fixed the leak on mine. <img border="0" alt="[Hillbilly]" title="" src="graemlins/notooth.gif" />
Re: Oil Leak Problem 3.1L engine #252299 05/08/03 10:10 PM
MattGold Offline OP
I got the O-Ring, where does it go? it doesn't look like it just fits over the distributer shaft? or do I have the wrong sized O-Ring?
Matt
Re: Oil Leak Problem 3.1L engine #252300 05/08/03 10:31 PM
AIR AMIGO Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Iclimbrocks2:
<strong>Check and replace the O-ring on the distrubutor shaft first. It fixed the leak on mine. <img border="0" alt="[Hillbilly]" title="" src="graemlins/notooth.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Is your o-ring just above the gear teeth on the distributor or is it at the base of the shaft? If it's above the gear teeth, what did you have to remove to get to the o ring?
Keith
"AIR AMIGO!" aka 1994 Isuzu Amigo SAS with Toyota axles, 5.29's, dual ARB's, IROK's, WARN HS9500 winch, and etc.
Pacific NW Isuzu Off-Roaders
Timber Tamers #172
Re: Oil Leak Problem 3.1L engine #252301 05/08/03 10:36 PM
You kinda have to stretch the O-ring over the shaft, don't worry it's normal.
Definately make sure its the right size. If it's even the slightest bit to big or small, it will leak like mad. I got mine at a GM dealership for about 50 cents. Good Luck <img border="0" alt="[Hillbilly]" title="" src="graemlins/notooth.gif" /> .
<small>[ May 08, 2003, 05:38 PM: Message edited by: Iclimbrocks2 ]</small>
Re: Oil Leak Problem 3.1L engine #252302 05/13/03 05:44 AM
The distributor shaft O ring oil seals never worked for me. I bought a sheet of high temperature gasket material (looks like what thermostat gaskets are made of) and cut a flat gasket, which I installed between the flange on the distributor and the engine block.
PHP: 7.4.33 Page Time: 0.010s Queries: 14 (0.008s) Memory: 0.6020 MB (Peak: 0.6709 MB) Data Comp: Off Server Time: 2026-07-14 09:58:39 UTC
