Re: What makes a water pump go bad? #254727 05/05/01 07:49 AM
Mean__Gene Offline
actually the flush i was talking about is a pint bottle you buy and throw in the system (for 10 mintues) to dissolve deposits out of your radiator... in ten minutes???, it must be some acidic crapola. and speaking of correlation, i had a water pump go out 3 days after using it.. correlation does not necessarily mena causation, but there it was...<P>yea, be careful flushing you system with cool water... if the temp difference is too much, it could crack the block like glass (or so i've heard...)<P><BR><P>------------------<BR>Gene Bosche'<BR>Mean_Gene@Pirate4x4.com<BR>1988 Toyota 4Runner SR5 V6<BR><A HREF="http://www.toyotaoffroad.net/gene/4X4/4Runner/4Runner.htm" TARGET=_blank>My 4Runner Website</A>
Your ad here.
Re: What makes a water pump go bad? #254728 05/05/01 10:54 PM
The water pump on my 99 4Runner started leaking last year. I only had 19,000 miles and no radiator flushes or anything. One day I checked under the hood before a long trip and I saw coolant residue under the engine and along the water pump--but I never saw any coolant on the floor and the coolant level hadn't dropped noticably. After they replaced the water pump I had small amounts of coolant oozing out of the junction between the oil pump and the water pump. After 10 more days in the shop and a couple of visits by factory reps they tear off the oil pan and pump to find coolant stuck in some vacant chambers that was starting to seep out when the engine was hot. Apparently when they replaced the water pump some coolant spilled into places it shouldn't have been and was slowly working its way out. They cleaned it up and resealed (and used way to big a bead of FIPG in the process) and I haven't had any problems since. It really does make me wonder--this is a Toyota Truck after all?? BTW, I've seen more than a few reports of water pump failures on these engines (mostly Tacoma owners).<P>Paul<BR>99 4Runner SR5 4wd<BR>5-speed
Re: What makes a water pump go bad? #254729 05/07/01 07:09 PM
Ken,<P>I don't remember the path for the s/c belt, but if it goes around the water pump mabe it was too tight. Also, when they flushed and refilled your cooling system did they use distilled or city water? I don't know if a couple of months with crappy water is long enough to cause this problem.<P>Pete
Re: What makes a water pump go bad? #254730 05/07/01 07:59 PM
ldivinag Offline
<BLOCKQUOTE><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><HR>Originally posted by PaulC:<BR><B> It really does make me wonder--this is a Toyota Truck after all?? BTW, I've seen more than a few reports of water pump failures on these engines (mostly Tacoma owners).<P></B><HR></BLOCKQUOTE><P>on my 90, the pump was till working when they replaced the block (HG inssue) at 112k... i just wanted to do the timing belt and everything else in there while the thing was opened...<P>------------------<BR>leo d.<BR>90 4runner, v6, auto, WCOR CitB kit,<BR>marlin duals, arb rear, tt front<BR>4.88, blah, blah, blah...
leo d.
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Moderated by  4Crawler, 4x4Wire, Dandeman, kewlynx
PHP: 7.4.33 Page Time: 0.007s Queries: 14 (0.005s) Memory: 0.6031 MB (Peak: 0.6613 MB) Data Comp: Off Server Time: 2026-06-21 18:51:59 UTC
