Page 2 of 3 1 2 3
Re: Turbo muffler's #259815 04/02/02 07:19 PM
Bratik Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by RandyM:
<strong>I have the Dynomax Super Turbo on my 2000 4Runner and like the sound and performance
Randy</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Do you remember the part # for the muffler and where did you get it from, also if you don't mind, how much was it?
Thanks for all the info.
<small>[ 02 April 2002, 01:21 PM: Message edited by: Bratik ]</small>
Re: Turbo muffler's #259816 04/02/02 07:48 PM
Sargent 'D' Offline OP
All, thanks for your inputs.
Randy, thanks for the rundown. Torque is what I don't want to lose, so I'll probably be going with your recommendation. Thanks!
Spence
Re: Turbo muffler's #259817 04/02/02 07:48 PM
Ishikawa Offline
Is anyone going to answer the question, or has this become the same pissing contest as all other muffler Q&A's?? I know nothing of the '86-'87 Turbo muffler that comes stock from Toyota....does anyone have any clue on this at all?? I wouldn't mind learning something new today.
You might try to Hardcore board, they seem to know older vehicles a little better. I know the regular 22RE has a smaller diameter exhaust than the 3rd Gens...but perhaps someone will chime in on experience with the Turbos.
Max
Re: Turbo muffler's #259818 04/02/02 07:51 PM
Paul
Here is the link for the specs on the Dynomax Super Turbo muffler. The part number is 17747 (2 1/4" center inlet/offset outlet). I'm not sure what the muffler cost, I had mine done at a local muffler shop (not a retail chain) for about $100 installed. They let me try the Magnaflow, Flowmaster and the Dynomax each for a week and didn't charge any extra to do this.
Randy
Re: Turbo muffler's #259819 04/02/02 08:35 PM
Randy,
You indicated 2 1/4" inlet. Isn't it supose to be 2 1/2" or am I wroo, wroooo, wroooong? <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Thanks
Pete
Re: Turbo muffler's #259820 04/03/02 01:26 AM
Pete,
Your factory exhaust has a 2 1/4" pipe, but a 2 1/2" will work.
Randy
Re: Turbo muffler's #259821 04/03/02 07:43 AM
What is a good price for the Dynomax Super Muffler?
-Patrick D
Re: Turbo muffler's #259822 04/03/02 07:45 PM
Randy, great info on the Dynomax. Can you tell us where you purchased the Monza Pacesetter tip and how much it cost you.
Also, when the Dyno was installed I presume they did some pipe cutting to replace the factory unit? I would like to unbolt the factory unit and have the muffler shop create a bolt on replacement using the Dynomax muffler. That way if I sell it I can just bolt on the ole factory muffler.
Thanks again
Phil
Re: Turbo muffler's #259823 04/03/02 08:20 PM
Philly, I think you are going to need a CATBACK system if you want to do that. They are a bit more expensive, but in situations where you want to be able to switch back and forth, it's worth it. I guess the biggest pain in the A$$ would be swaping back and forth.
Re: Turbo muffler's #259824 04/04/02 12:21 AM
Sarg, you're probably right, I've used Dynomax in the past and was pleased with there sound and performance. I also wanted to keep this inexpensive and Dynomax is very inexpensive. Maybe I can get the local small town muffler shop to fabricate a system for me with the Dyno.
Phil
Page 2 of 3 1 2 3
Moderated by  4Crawler, 4x4Wire, Dandeman, kewlynx
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6277 MB (Peak: 0.7486 MB) Data Comp: Off Server Time: 2026-10-23 11:19:16 UTC
