Page 2 of 4 1 2 3 4
Re: stumped #27061 02/27/03 12:10 AM
ryno Offline OP
bump...
what about a clogged cat? truck has 226 and original cat and exhaust. are these the symptoms of a clogged cat? after warm up it flows like crap? i thought clogged was clogged.
does carbon build up on the butterfly have something to do with it?
Exhuast leak?
maybe my timming. i'm goin to pull the cap and rotor today and see if there is corrosion. but this came on all of a sudden and i have no idea where to start. will the ECU throw diag codes even if there is no check engine light lit?
thanks for all your input
ryan
89 4runner V6 33 MT/R GoodYear,the only way to go. open front and e-locker rear.4:88....Truck's needs are deeper than my wallet. so i got another truck <img src="/forums/images/graemlins/smile.gif" alt="" /> 85 4R I6 T 35 TRD rear dual case 4.56 lets go wheeling :P
Re: stumped #27062 02/27/03 12:43 AM
DirtyHarry Offline
Toyota Moderator
I think that the most telling sign is that it does not happen when the the motor is cold and in open loop mode. That tells me that the problem is a sensor and not a mechanical item like the cat or valve seals. If it were the cat, you would have the problem all of the time, not just after it warms up.
Re: stumped #27063 02/27/03 01:53 AM
toyrker Offline
If it is TPS equipped, check & adjust per 4Crawlers web site instructions. Its amazing what this little piece of plastic can do. It sometimes does not set code, & will malfunction hot or cold & will effect other or be effected by other faulty sensor readings. It will sometimes be a intermittant problem & will be hard to diagnose. This is a very sensitive sensor. Just a guess. But i have had similar problems. Especially after doing any fuel system maint. or removal of such.
85 4runner, 22re,cam, headers,2.25free flow exhaust,3"susp lift, 33's,custom bumpers,& stuff
Re: stumped #27064 02/27/03 04:11 AM
hubsj Offline
If there is a good bit of build-up on your throttle body, you may want to check your recirculation points.
When I took apart my engine I noticed thick build up almost everywhere. From the exhaust recirculator from the header, in the back of the engine (a cover with a "tube" in it), throughout the entire TB, I believe the lack of air and flow was my problem. Althought this problem, black thick stuff, did not come and go, the poor running of the engine did come and go..
GO FIGURE.
Good luck
88 4runner 22re 5spd 30x9.5 bfg AT
daily driver - weekly off roader.
284,400= Jasper - hello 5th gear!
true Thorley Header - V6 3rd
Valid inspection sticker (289,000)
Re: stumped #27065 02/28/03 01:28 AM
ryno Offline OP
TPS checked within specs
New Cap and Rotor
old one was warn a little
WTF do i do now??!
timing? what other sensor would make it run like this..
after 3200 when running like crap it just flat falls on its face and revs out.. i'm gonna try to screw with the timming but i don't really think thats what it is..
iunno bout to take it to toyota
ryan
Re: stumped #27066 02/28/03 01:40 AM
Frankenyota Offline
Before you take it to the stealer....uh dealer take a hammer or other suitable tool and give your EGR valve a good thunking. If it is stuck open it will run like crud at low rpm but it should run ok at higher RPM, maybe you have multiple problems.
1986 4X4, 1991 22RE, 5.71 gears,ARB Rear, aux fuel tank, 3mm O/S TB/intake, engnbldr cam, LCE header, magnaflow w/2.25 exh. custom 4 color paint job :-P 33X12.5 Goodyear MT/Rs
Re: stumped #27067 03/09/03 10:33 PM
ryno Offline OP
checked the timming today and it appears to be at 8 while jumped which is out of spec. i'm goin to clean the throttle body and pull the efi fuse. i hope this will cure my ailments. how would you go about adjusting the timming? i see nothing about it in the FSM
thanks
89 v6
Re: stumped #27068 03/09/03 10:37 PM
hubsj Offline
The distributor mounts to the side of the head with one bolt. Loosen this bolt and you can turn and your distributor, advance or slow the timing by turning it in either direction.
Re: stumped #27069 03/09/03 10:43 PM
hubsj Offline
Re: stumped #27070 03/09/03 11:37 PM
I don't think I read it in the reply's...EFI or Carb? if carb it sounds a lot like a stuck auto choke. If EFI dose it have a MAF? if so it may need cleaning. Sounds a lot like a to rich of mixture at warm up. Sorry if I missed something in the reply's.
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 14 (0.004s) Memory: 0.6369 MB (Peak: 0.7425 MB) Data Comp: Off Server Time: 2026-06-07 07:02:36 UTC
