Re: 37's or 35's on stock birfs
#285896
07/15/03 08:54 PM
Broke 1 birfield so far with 35s. It was the ideal situation to break one...trying to pull a high-centred Jeep (what else??? <img src="/forums/images/graemlins/notooth.gif" alt="" /> ) so I was in reverse and because of the rocks around us, I had to try to pull at an angle, hence had my wheels turned.
[Re: Bigbluemax]
#285897
07/15/03 09:14 PM
Toyota Moderator
2. How does dual cases help steering 2wd?, did I miss something?
You can put the front case in low range and still be in 2WD so that you do not have the adverse effects of the front locker. Brian needs one to help his driveshaft angle too. <img src="/forums/images/graemlins/wink.gif" alt="" />
[Re: DirtyHarry]
#285898
07/16/03 12:47 AM
You can put the front case in low range and still be in 2WD so that you do not have the adverse effects of the front locker. Brian needs one to help his driveshaft angle too. <img src="/forums/images/graemlins/wink.gif" alt="" /> Ha! What I need is a high pinion ARB locker. About $1500 dollars later and I think all my problems would be solved. It's just convincing the other half that I need to spend the money that's a little difficult. <img src="/forums/images/graemlins/frown.gif" alt="" />
[Re: Brian894X4]
#285899
07/16/03 01:14 AM
You can put the front case in low range and still be in 2WD so that you do not have the adverse effects of the front locker. Brian needs one to help his driveshaft angle too. <img src="/forums/images/graemlins/wink.gif" alt="" /> Ha! What I need is a high pinion ARB locker. About $1500 dollars later and I think all my problems would be solved. It's just convincing the other half that I need to spend the money that's a little difficult. <img src="/forums/images/graemlins/frown.gif" alt="" /> i'll have to agree on that one.all she says is "more money on that !@#$@# truck!! when will you be done with it?" and she hates it when i tell her that it's a truck and will never be done and if i finally call that truck done,its time to get a new truck and start over <img src="/forums/images/graemlins/grin.gif" alt="" /> boy does that make her boil LOL
#285900
07/16/03 01:45 AM
at my age i have it the worst, i have to explain to my mom and my gf <img src="/forums/images/graemlins/grin.gif" alt="" />. i cant wait to get these MTR's on the truck and off the pavement though. i just have to mount the cab and get at it.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6080 MB (Peak: 0.6741 MB) Data Comp: Off Server Time: 2026-06-17 12:59:50 UTCValid HTML 5 and Valid CSS
