2.6 noise. Lifters? #288536 07/19/03 07:40 PM
tkal Offline OP
I got this noise. I am pretty sure it is coming from the top half of the motor. I believe it to be from the lifters. I have hydro lifters. The noise comes and goes. It is never there when I start the truck. Dedpening on how I drive it, it will start between 5-15 minuets in the drive. It will stop sometimes. Recently I have discovered that if I hold the rpm up around the 3-4k range with no load will get rid of the noise. Any ideas?
'88 D-50 2.6 needs some love.
Re: 2.6 noise. Lifters? [Re: tkal] #288537 07/20/03 01:37 AM
tkal Offline OP
Pages are too small.
Re: 2.6 noise. Lifters? [Re: tkal] #288538 07/20/03 04:10 AM
Tkal:
Did you dis/reassemble the rocker arm shafts when you did the rebuild?
It is possible to put the shafts in backwards or upside down, or a combination of both...this will result in wear, noise, and ultimately fractured rocker arms after seizing agains the shafts under load.
Plugged up rocker shafts (sludge) can cause this problem as well. The shafts should be "flowed out" with parts washer solvent during rebuild to ensure no blockages exist, and the passages in the rocker arms should be flowed too.
I'd pull the rocker cover and compare what's set up there to what you find in the workshop manual, then pull the shaft assembly and reassemble (hint: use vaseline to hold your lifters in place when reassembling)...and I'd suggest you do it now rather than later to save some $$$.
Hope thin helps.
Rob in Hell
Re: 2.6 noise. Lifters? [Re: tkal] #288539 07/20/03 04:44 PM
powerRam50 Offline
) these dome hyd lifter seem to always nock i have a fairly new head and mine knock all the time i just ignore it till it fries but it hasent(darn it i want a non jet head but this thing just keeps going <img src="/forums/images/graemlins/angry.gif" alt="" />
Re: 2.6 noise. Lifters? [Re: tkal] #288540 08/15/03 03:20 AM
tkal Offline OP
What do you all think? Someone at work suggested that the lifter is "smashed" Or more closely it cant keep up enough pressure to avoid the clicking noise. Which would explain why if I idel it, the noise will go a way. And it is louder the harder I drive it.
So my next question would be any ideas on how to locate exatly which one is making the noise? I do not have eight that I can toss in. I am planning on grabin one from my old head and using that.
Re: 2.6 noise. Lifters? [Re: tkal] #288541 08/19/03 04:59 AM
tkal Offline OP
Bad lash adjuster is what I was trying to say. PowerRam50 This is not a little noise, not even a loud noise. I can hear ths noise at 2k rpm driving 55 mph That is with windows down and my loud tires.
Re: 2.6 noise. Lifters? [Re: tkal] #288542 08/20/03 11:49 PM
tkal Offline OP
no one has anything else to say?
Re: 2.6 noise. Lifters? [Re: tkal] #288543 08/21/03 04:56 AM
DanWheeler Offline
well if it doesn't happen at idle your going to have a hard time tracking down an individual lifter. See if you can find someone that will sit in the engine compartment with your hood off while you go 50 with a short section of hose. He can put one end to his ear and the other on the valve cover and move it around to see which lifter it is.
1986 Montero 2.6l
31X10.5 BFG MT - Weber carb with custom intake
Rear LSD - RCI seats - Oil cooler - Manual hubs
Custom bumpers front and rear + rock sliders
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6207 MB (Peak: 0.6991 MB) Data Comp: Off Server Time: 2026-11-17 13:02:11 UTC
