Buying a used 2000 Tracker??? #292381 07/28/03 05:17 AM
troopinstile Offline OP
Hi my name is Dave I'm from the Isuzu forum, we've been looking around and came accross a 2000 Tracker 4 door with a four and a stick. Are there any coments, or things to look out for?? Any info would help <img src="/forums/images/graemlins/cheers.gif" alt="" />
A Wise man once said, Wherever you go........there you are
Bone stock 90 Trooper 2.6, 5 speed. With the aerodynamics of a brick, and the power to match.
2000 Chevy Tracker, also bone stock, well, at least until it's paid off!!!
Re: Buying a used 2000 Tracker??? [Re: troopinstile] #292382 07/28/03 10:56 AM
My '90 two door is probably too old to make a good comparison, but...
Good overall quality
Rugged vehicle
Easy maintenance
Great visibility
Dependable
Rough ride (goes with being rugged I guess)
Underpowered (1.6L 8v)
Rust on all three door sills (not much, but there)
Really bad safety review (I believe the 2k's is much better)
Hope this helps, good luck.
Re: Buying a used 2000 Tracker??? [Re: troopinstile] #292383 07/29/03 04:54 AM
Thanks for the info, we bought it, talked down the dealer a little and actually traded my 90 Trooper in on it. It was shot anyways, the frame was rotted out in the rear cross member and was going by the front wheel, and lately I just couldn't get it to run right, I think it had a bad injector, or something along that line. It was just too old and too far gone to start experimenting with parts. I hope it holds up well, it was a lease turn in , and Gm certified used, so it extends the warrenty, the tires are like new, as is the rest of the truck. In fact, we thought it was a 2003!!! It's just that clean. Thanks again. Dave <img src="/forums/images/graemlins/cheers.gif" alt="" />
Moderated by  4x4Wire, code33
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5917 MB (Peak: 0.6448 MB) Data Comp: Off Server Time: 2026-07-16 01:38:47 UTC
