NW4runner / Tragerr's Runners #295068 07/31/03 07:24 AM
E
esun127 Offline OP
Any updates on those two beasts? How much did they end up costing? Anyone know?
Re: NW4runner / Tragerr's Runners [Re: esun127] #295069 07/31/03 05:32 PM
Niether one is ready.
Trager sold his heads to NW and that left Trager without heads. There was a deal in the works to have a high end shop do CNC work on new heads that where going to be sold in numbers, but presonallities between the sons of the two shops got in the way of making money so the deal fell apart.
Trager is having his heads done by another shop and should be ready soon.
NW's engine was used to test the new head gasket design. The new head gasket design held fine with a destructive test proceedure.
Gadget
Re: NW4runner / Tragerr's Runners #295070 07/31/03 08:24 PM
They could test those motors in my 4R if they want to. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: NW4runner / Tragerr's Runners #295071 08/01/03 01:53 AM
You are kidding? Trager is again without a complete engine?
Re: NW4runner / Tragerr's Runners #295072 08/01/03 05:07 AM
I spoke to Trager tonight.
More changes are in the works. He is going to use different turbos now. It seems that MAWs did not do there math right again and the turbos are the wrong size.
It seems that there is some serious motivation now to get the two 4Runners done and out of there. I was told 6 weeks max, but I'll bet it is more like 12.
So, how is your engine project coming along? Is it running yet?
Gadget
Re: NW4runner / Tragerr's Runners #295073 08/01/03 06:22 PM
Gadget
Started her up Tuesday!! <img src="/forums/images/graemlins/kewl.gif" alt="" /> So far so good. I have to get it to the exhaust shop, hopefully today, to get the pipes fabbed for it so I can drive it. It has one small coolant leak that will be somewhat of a biotch to fix. Small tube [that should be] pressed into the throttle body leaking.
Thanks again for the hoist, it was a life saver! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: NW4runner / Tragerr's Runners #295074 08/02/03 12:32 AM
Glad I could help. Just let me know the next time you are providing lunch and I will be there...
You can bypass that TB hose until you get it fixed.
Gadget
Re: NW4runner / Tragerr's Runners #295075 08/02/03 11:50 AM
Destructive Test Procedure... very well put.
Sorry I missed the EC4J guys.
Gadegt - I'll give you a call when you SHOULD come to Chicago. It was one fast MF while testing the timing chain tensioner. <img src="/forums/images/graemlins/grin.gif" alt="" />
Re: NW4runner / Tragerr's Runners #295076 08/03/03 12:50 AM
I thought you would like how I worded it.
Yes I will make the road trip to visit with you. I have so much use or loose leave at work and I would hate to give it back to them.
Gadget
Re: NW4runner / Tragerr's Runners #295077 08/03/03 12:46 PM
E
esun127 Offline OP
Hey NW,
What would it cost to have something setup similar to yours? I've been running 5psi boost for a long time... I took a break from mods and now I'm ready to go back. I'm not looking to get 450hp, but I'd like to run 300+ without having to boost so much (hence your setup, which seems to be much more efficient with the intercooler) I would run less than 10psi. Are you running something like 12-15? Would I need to get work done on my heads, pistons, rods, etc? Thanks.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6139 MB (Peak: 0.7023 MB) Data Comp: Off Server Time: 2026-11-17 08:59:42 UTC
