Page 1 of 3 1 2 3
flex a lite 295 #299480 08/09/03 02:51 AM
dogslovetrucks Offline OP
I need a new mechanic. Flexalite says its a 3 hour job max to mount the fan and I believe them, but I was playing with my son, and dropped the truck at the mechanic who then took 8 hours to mount and wire the fan (I will be paying for 3 hours of labor) and I am not pleased with how it was mounted.... I also missed a 1800 CFS release on the lehigh river due to a lack of truck, which makes me even more irritable... you want road rage, I got some right here!
on to the fans. They move a boat load of air! they come on fast and seem to work well, I am going to be driving about 300 miles over the next 3 days so I will keep posting on mileage/power/ac changes
Re: flex a lite 295 [Re: dogslovetrucks] #299481 08/11/03 12:24 PM
I did a 250 mile trip with the new fans in place, and so far, the temp gauge did not go past half way, the A/C was definitely better, and it seems like there is more power. (not as big an improvement as lots of stickers or a 7 inch diameter tail pipe though) it seems like I am going 70-85 with about 250 less rpm, and I think I am getting a little better milage ( I need to run about 750 more miles to be sure) I am going to be fixing the mounting brackets that my ex mechanic screwed up and hopefully gain some more effiecency.
Re: flex a lite 295 [Re: dogslovetrucks] #299482 09/01/03 07:22 AM
Tell me more, is this a dual fan system, does it come with a temp sensor? I hate the stock fan, makes too much noise!!
Re: flex a lite 295 [Re: dogslovetrucks] #299483 09/01/03 01:08 PM
H2O_MAN Offline
Sounds like you are pleased with your latest mod.
Could you post some pictures? - Thanks.
Re: flex a lite 295 [Re: H2O_MAN] #299484 09/02/03 01:00 AM
I cant post pictures yet because I do not yet have a digital camera, (I am going to start shopping for one soon...)
1000K review....
I can not hear the fan at all at over 10 mph, and can just make it out windows down, stopped, no radio.
I am not seeing the HUGE power benifits, but I am turning about 250 rpm less at 75-80 and I am not lagging as badly up the long I-78/ I-80 uphills with full load and A/C on, so I like it!
Re: flex a lite 295 [Re: dogslovetrucks] #299485 09/02/03 05:48 AM
Kookadala Offline
what was the price range for the fan/labor? I heard these fans are pretty expensive. Do you have an on/off switch inside so you can shut the fan off for watere crossings?
96 T100 4x4 - 35's, 4" SL, 2" BL, 4.88s, ARBs, custom bumper & E9000 winch, etc.
99 F-350 4x4 superduty supercab turbodiesel longbed
Re: flex a lite 295 [Re: Kookadala] #299486 09/02/03 12:04 PM
The fan was 360 from summit racing, and if you can install, a car stereo, you can probably do the labor yourself. My mechanic had a bill stating 6 hours, but we discussed it, and I paid for one hour of labor (to do the wiring..)
I modified the brackets to fit with a jigsaw (metal blade) and angle grinder, and it went in pretty easy.
The fans do have a manual overide for water crossings, and I put it in even though I thought I would never ever need it. (if I see water I will a) kayak it, b) go around)
24 hours later, the switch was being used as I was fording 18+ inches of water from flash floods in PA trying to get home from boating.
Re: flex a lite 295 [Re: dogslovetrucks] #299487 09/02/03 05:49 PM
uzombie Offline
Are those the BIG 27" fans ? Two, one higher than the other, with the electrical connections at top?
I was curious as there is a Flex-a-lite Black Magic fan (single) that is designed for Toyotas...
My OEM sounds like a school bus.
Ed-
Re: flex a lite 295 [Re: uzombie] #299488 09/02/03 11:28 PM
they are listed as a 27 inch fan, but they are a pair of staggered 13.5 fans
http://www.flex-a-lite.com/auto/295.htm
my wife and I figured that it is about 19% more fan area than stock, and with the gasket seal, it sucks more air through the radiator as opposed to around the shroud.
I am getting about 1 mpg better too, (over the last 1K miles)
I talked to flexalite, and the black magic fan will work (kindof) but has less fan area than the 295...
Re: flex a lite 295 [Re: dogslovetrucks] #299489 02/02/05 05:21 PM
Brew Offline
Bump <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
4XGeek wanted some tips on the Flex-a-lite install.
Here are two links I used to get enough info for my mechanic friend and I to do the install.
http://www.gadgetonline.com/Fan.htm
http://www.nsmfinance.com/toyota/flex.htm
Hope this helps. Brew <img src="/forums/images/graemlins/cheers.gif" alt="" />
98 T100 SR5 4x4 3.4L auto, TRD Goodies, Bilsteins, engine/TC skids, 2" body/d.train lifts, F/R ARBs, 4.56 R&Ps, Aisin hubs, 255/85R16 Dunlop Rover RVXTs (street), 16x7 +8mm offset wheels, custom bumpers, Warn M8000, Master-pull synth. line
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6339 MB (Peak: 0.7580 MB) Data Comp: Off Server Time: 2026-07-12 15:44:21 UTC
