Page 1 of 3 1 2 3
Center console/arm rest swap. #302295 08/15/03 04:21 PM
Canucklehead Offline OP
Anyone know if a 2nd Gen. Rodeo console/arm rest will fit a '97 5spd 4WD? Those cup holders sure would be nice. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Steve
'97 Rodeo 5spd. 3.2L SOHC V6 4WD
Re: Center console/arm rest swap. [Re: Canucklehead] #302296 08/16/03 02:00 AM
I have that same problem so what i did was I got one of those cup holders that you put on your window. Cut it, painted it and screwed it front of the change bin. But I will eventually go tuffy console.
Re: Center console/arm rest swap. [Re: Canucklehead] #302297 08/16/03 04:17 AM
I will take pics.
Friend of mine bought 96 rodeo and it comes with different arm rest then mine '95.5 and there is cup holder in the arm rest, I can't explain I will post pics tomorrow, but is direct bolt on no mods needed.
Re: Center console/arm rest swap. #302298 08/17/03 07:10 PM
SOURCE7769 Offline
you have any pics yet for the console swap????
97 rodeo 3.2 4wd
Re: Center console/arm rest swap. #302299 08/17/03 11:10 PM
Your friend's '96 probably has the same console as my '97. If so, the cupholder is underneath the arm rest pad. In order to use it you have to have nothing in the storage space and leave the armrest pad up. <img src="/forums/images/graemlins/confused.gif" alt="" />
At least the '98 and up have the cup holders where they are functional.
Steve
Re: Center console/arm rest swap. [Re: Canucklehead] #302300 08/17/03 11:38 PM
Yeah the same one,but that is much better then nothing like mine and most of the guys.
I have never seen 98+ one..
Re: Center console/arm rest swap. [Re: Canucklehead] #302301 08/18/03 12:05 AM
Bansil Offline
The cup holders are ok....yeh..uh..ok on 98 rodeo...
as long as you find the "right" cup.I always forget
and use the "rodeo" cups in the morning <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/shiner.gif" alt="" />
<img src="/forums/images/graemlins/shiner.gif" alt="" /> that wil "p---" (upset) off the wife she has 3 speciallty cups that fit the holders all normal cups will not fit.I have found this out the hard way <img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/shiner.gif" alt="" />
Isuzu needs to sell "rodeo"cups...she says"catipillar cups
work great"
Doug
p.s. just my .02...
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: Center console/arm rest swap. [Re: Bansil] #302302 08/18/03 03:55 PM
Kevin Armstrong Offline
I bought the perfect cupholder from a guy named "Tom in Roswell" from the old v-mag boards several years ago. He had a friend that had an injectiong molding facility I believe and was able to fab a few of these up. I think I purchased one of the last few made, before they ran into problems and were no longer able to produce.
The texture is the same as factory materials, and the color is almost an exact match (although this pic makes it look a little off - guess due to camera flash and material differences. It just drops right into place under the e-brake. Is a tiny loose, so I just plopped a dab of that yellow easy-release modeling clay on the bottom and it's snug as a bug. This was a pic I took when installing my cb, so it's not centered on holder, but I'll try to get a better one later.
(ignore the piece) <img src="/forums/images/graemlins/cool.gif" alt="" />
Now, there's no way I'd ever get rid of this holder while I still own the rodeo, but I thought this may give some of you guys some ideas if you have the technical ability to fab something up like this.
Kevin
95.5 Rodeo 4wd
Basic 2" Shackle/T-bar lift
BFG a/t 265/75/16's
www.armstrongsonline.com
I have dibs... [Re: Kevin Armstrong] #302303 08/18/03 07:34 PM
...when you get rid of your Rodeo!!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Steve
Re: Center console/arm rest swap. [Re: Kevin Armstrong] #302304 08/18/03 08:43 PM
I use the space btw the E-brakes and the pass. seat as well, but that holder is really nice, and piece is nice too <img src="/forums/images/graemlins/notooth.gif" alt="" />.
Do u have any contact email to that guy so we can email him and see if he can do someting about us w/o one.....
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6301 MB (Peak: 0.7540 MB) Data Comp: Off Server Time: 2026-05-27 08:09:31 UTC
