transfer case leaking!!!!
#302452
08/16/03 01:35 AM
Guys...I just had my transfer case re-sealed and after 4 months off-roading it started to leak again. The mitsubishi guys said that its a common problems for 96' Montero to be leaking like that. So my mechanic tried an aftermarket seal or gasket to use on my montero and hopefully it works. I was just wondering.....does any of you have the same problem with you monty. <img src="/forums/images/graemlins/confused.gif" alt="" />
Exploring the outback is my game!
2005 Mitsu Gen3 Limited OME Custom Suspension Custom made safari roof rack Garmin GPS 32X12.50X16 BFG Mud Terrain
1997 Mitsu Gen2 LS Safari Roof rack Garmin GPS 33x11.50x15 BFG MUds
Re: transfer case leaking!!!!
[Re: Gellekanao]
#302453
08/16/03 04:47 AM
The mitsubishi guys said that its a common problems for 96' Montero to be leaking like that. Oh common!!! you can always expect to hear that from a lazy couch potato that has no interest in fixing the problem for you. <img src="/forums/images/graemlins/oink.gif" alt="" /> Rovers are the exception to the rule but like that popular saying " If a Rover doesn't leak is because something is wrong", but no, I have never hear anything like it about the 96 Montero. <img src="/forums/images/graemlins/cheers.gif" alt="" />
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
[Re: JAVYPRO]
#302454
08/16/03 06:15 AM
If they have replaced the t/case seal then the slip yoke is leaking internally. There is a brass plug inside the slip yoke which seals it, eventually the plug corrodes through. Three choices here, replace it with a new item, remove your one and replace the plug or seal it with something like an epoxy.
I just luv my "clacker Jabber".................
[Re: Mister Bishi]
#302455
08/16/03 03:11 PM
Another note. Its common to get little spirts of fluid when flexing out off-road, particularly on Gen II. It is a very minor amount though. Its mainly a function of the LWB and the shaft pulling down on the seal.
[Re: Lloyd Swartz]
#302456
08/19/03 07:39 AM
thanks for the replies guys...lates!
clint <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Gellekanao]
#302457
08/19/03 04:43 PM
Just sealed welsh plugs on both front and rear output shafts. (can you say "basket?"). It seems to have solved the rear, but not the front... think my t-case is trashed? Ooooooh yeaaaaah... <img src="/forums/images/graemlins/shiner.gif" alt="" />
BTW, I used "seal-all", which seemed to do the trick.
[Re: PHIL_]
#302458
08/19/03 09:14 PM
BTW, I used "seal-all", which seemed to do the trick. Phil, Might be time for Misterbishi's xcase gearing while you're in there rebuilding it. Ray
[Re: off-roader]
#302459
08/20/03 05:03 AM
That would be a good idea Ray, but I just can't justify the $$ when the rest of the rig is coming apart. It needs a gas tank, tcase, tranny, valve seals, more than two body panels, new front CVs, etc, etc. My plan is to keep it going as long as possible with minimum $$, until I can afford to go down and visit those crazy AZ boys, and bring myself back a cherry, sun-kissed SWB GenI in a year or two. Then I'll swap over my naughty bits, and have a beast worth putting gears into. <img src="/forums/images/graemlins/drunk.gif" alt="" />
PHIL
[Re: PHIL_]
#302460
08/21/03 04:24 AM
now you're talking my language ... keeping my rig together while wheeling it as often as possible, its kind of like triage, prioritizing the maintenance and mods ... sometimes i feel like a MASH unit <img src="/forums/images/graemlins/shiner.gif" alt="" />
had an '88 Montero, then an '04 Rubicon ... sold 'em tho
