knock sensor questions....
#307663
08/27/03 06:16 AM
anyone ever have to replace the no1 knock sensor on there 3.0 v6?...where is it and how hard is it to replace???
Re: knock sensor questions....
#307664
08/27/03 08:24 AM
*Well I dont have the V6 but based on previous discussions my understanding is that its located underneath the intake. Not sure if its between the upper and lower or all the way down...but everyone says its a biatch to get at. Check your wire as far as you can first and maybe save yourself some work. Are you getting an error code related to the knock sensor? Generally they dont go bad...but the wire commonly does. ~Darin <img src="/forums/images/graemlins/baby.gif" alt="" />
88' 4x4 *22R-EB Gen II* 87' $Runner *22R-EB Gen I* 85' Sillyca 22R-Esq  "I LIVE IN MY OWN WORLD...THEY KNOW ME WELL THERE"
[Re: Esquire812]
#307665
08/27/03 01:41 PM
man its NOT easy. pretty much at the center of the motor, you pretty much tear down the whole top end to get to it.
#307666
08/27/03 03:46 PM
It's not too hard. You WILL also want to replace the wire that runs between the head and intake manifold. After paying the cost on the knock sensor and intake manifold gaskets, the wire is cheap.
Plan on extra expenses. Hoses you might not know existed may need replaced. You may want to replace your timing belt and check both your idler pulleys since you'll be in the area anyway.
[Re: JackKnife]
#307667
08/27/03 03:50 PM
Toyota replaced my truck's knock sensor wire at no cost to me when they did my headgasket. They claim these wires have given them trouble due to heat, so you might want to look there first.
2000 4Runner | 5-speed | E-locker | Tundra/OME 2" lift | Stubbs Sliders | Deckplate/TrueFlow |
#307668
08/28/03 04:07 AM
its so tight in there behind the power steering and a/c pump that i cant find the wire....where does it lead to?...the wire harness?
#307669
08/28/03 04:36 AM
You are looking in the wrong place. The wire is under your throttle body. Here's a picture I stole:
[Re: JackKnife]
#307670
08/28/03 07:05 PM
BOYYYYyyyyy i sure wish my v6 looked that clean
<img src="/forums/images/graemlins/notooth.gif" alt="" />
89 4runner V6 33 MT/R GoodYear,the only way to go. open front and e-locker rear.4:88....Truck's needs are deeper than my wallet. so i got another truck <img src="/forums/images/graemlins/smile.gif" alt="" /> 85 4R I6 T 35 TRD rear dual case 4.56 lets go wheeling :P
[Re: ryno]
#307671
08/30/03 11:22 PM
that's my V6 <img src="/forums/images/graemlins/smile.gif" alt="" />, but it doesn't look that clean anymo...
ifya do a search, you'll find out more specifics on this repair
Toy4x 90 ExCab SR5 V6 Auto In need 99 Taco samesame(ish)
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6151 MB (Peak: 0.7008 MB) Data Comp: Off Server Time: 2026-06-10 16:47:46 UTCValid HTML 5 and Valid CSS
