Re: CEL code [Re: tlab] #308918 08/30/03 09:15 PM
Axe Man Offline
Kia Moderator Emeritus
Could that be the reason that every once in a while I get a cel come on for maybe a few days or weeks then all of the sudden go off on it's own. Or do you think it would more than likly be the gas cap deal. I know I should have the cell checked but I just never find the time to do so.
How long does the code stay in the computer again? I now you said it before.
The code more or less stays in the computer forever until it's either reset with a scan tool or the battery is disconnected. The CEL stays on only as long as the fault is actively occuring or if the problem is intermittent it may go off after several engine start/stop cycles.
Just because you get a CEL doesn't automatically mean it's the gas cap. There are dozens of conditions that can set it off.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: CEL code [Re: LadyFrog] #308919 08/30/03 09:23 PM
LadyFrog Offline OP
also ...
crawled all over under around...looked at connections and for loss wires...everything looks good as far as at the connection <img src="/forums/images/graemlins/confused.gif" alt="" /> going to check the wires for voltage/ohm stuff...wiring is ugly trying to follow under there... <img src="/forums/images/graemlins/barf.gif" alt="" />
LadyFrog
I miss my little Kia
Re: CEL code [Re: LadyFrog] #308920 08/31/03 01:42 AM
Axe Man Offline
also ...
The wiring and connectors probably will look good, but still be crappy. As you mentioned voltage and resistance checks will tell the story.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5998 MB (Peak: 0.6536 MB) Data Comp: Off Server Time: 2026-06-17 03:39:41 UTC
