Page 2 of 3 1 2 3
Re: cab/box swap [Re: Elbow_Greese] #310420 09/03/03 02:45 PM
dildinon Offline OP
the extracab from 89-95 is longer than the extracab of the 84-88
Many people have put 89-95 beds on the 84-88 frames
so if the cab is longer and the bed is the same length wouldnt the frame have to be longer?
Davin Nisser
'94 Pickup Xtra Cab Deluxe 3.0 V6 5spd...'84 lwb frame swap with 2" body/drive train lift and solid axle in the works...
Re: cab/box swap [Re: dildinon] #310421 09/03/03 03:37 PM
Elbow_Greese Offline
I would assume so, but you know what happens when we assume <img src="/forums/images/graemlins/ignore.gif" alt="" />
Only one way to find out for sure.
Measure it!
I don't have either kind of truck, so I don't know.
Todd
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: cab/box swap #310422 09/03/03 04:27 PM
DirtyHarry Offline
Toyota Moderator
I love the turbo engine, I can keep 55 up very steep hills and thats with only exhaust done, the only problem is it's a stand cab and I really want the extra room of an extra cab or 4runner.
I am not sure which would be easier, or to be more accurate, which would be less of a PITA, swapping the motors or the cabs. Remember, if you do a cab swap you have to disconnect everything from the engine anyway. Sensors, radiator hoses, wiring harnesses, etc. You also would likely need to gut the entire cab in order to make it a managable weight for moving. The 4Runner body is much heavier and larger too, so that presents a challenge that I haven't faced.
Re: cab/box swap [Re: dildinon] #310423 09/03/03 05:04 PM
bkg Offline
The frames are NOT the same. The frame is indeed 10" longer in the center - 112" vs 122" wheelbase.
There also were not just two frames in the mid 80's, there were three: Short WB pickup, 4Runner, Long-box/xcab.
4Runner/pickup frames are not the same. - they are VERY similar, but not the same. Maybe BudR can pipe in????
Brian K. Gallus
Re: cab/box swap [Re: bkg] #310424 09/03/03 06:36 PM
Yup, I have that 3rd type of 84-88 frame.
As for the 4runner/(std cab short bed)pickup frame, I think they are the same legnth, but the body mounts are different.
Maybe the extracab/longbed of the 84-88 are the same legnth of the 89-95 extracab? Anyone know the measurements?
Todd
94 2wd v6 extracab
Re: cab/box swap [Re: Elbow_Greese] #310425 09/03/03 08:00 PM
bkg Offline
Todd
I'm 80% sure the pickup/4Runner frames have different rails. The 4Runner's don't rise as much behind the 2nd body mount. Pretty sure - could be wrong.
The 84-88 xcab is 10" SHORTER than the 89-85 xcab. The frames are NOT the same.
Brian K. Gallus
Re: cab/box swap [Re: bkg] #310426 09/03/03 09:05 PM
I was refering to the 3rd mid-80's style frame, the xtracab longbed (what I have) (RN70 frame).
I was wondering if that was similar in legnth to the 89-95 xtracab.
Todd
94 2wd v6 extracab
Re: cab/box swap [Re: Elbow_Greese] #310427 09/03/03 09:45 PM
bkg Offline
Todd
Never seen one in a 4x4... only 4x2's... Huh... learn something every day!
Brian K. Gallus
Re: cab/box swap [Re: bkg] #310428 09/03/03 10:10 PM
DirtyHarry Offline
Toyota Moderator
Elbow Grease has a 2WD Xtra Cab longbed. You are right though, not too many of those hanging out around here.
Even more rare, my cousin has a turbo 4WD Custom Cab that has about a 140" wheelbase. <img src="/forums/images/graemlins/shocked.gif" alt="" />
Re: cab/box swap [Re: DirtyHarry] #310429 09/03/03 10:44 PM
Rauch_Off_Road Offline
If you want more power for your 4runner then I would suggest you look into a 5mge or 7mge swap. You will have more power over a longer power band and no turbo to contend with. I would think it is as much work as any other swap. I have been a supra owner for a long time and the inline 6 motor (supras and cresidas) is very impressive. pound for pound some of the best motors ever made IMHO. <img src="/forums/images/graemlins/mrt.gif" alt="" />
(aka suprathepeg, aka Sean)
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6469 MB (Peak: 0.7527 MB) Data Comp: Off Server Time: 2026-06-17 11:40:02 UTC
