Page 3 of 3 1 2 3
Re: 22RE smokes blue, white, and brown [Re: axledeep] #312867 09/12/03 02:45 PM
A
axledeep Offline OP
Hmmmm, no one has any thoughts on this <img src="/forums/images/graemlins/confused.gif" alt="" />. I could sure use some help........ <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 22RE smokes blue, white, and brown [Re: axledeep] #312868 09/12/03 06:21 PM
Happy Birthday Esquire812 Offline
Thoughts....for carbon buildup removal get a can of BK44 (I think) from Toyota. As far as the compression results, they are awesome. High yes...but what matters is they are even within a few PSI of each other. Cracked head wont show up on compression check until its to big to close itself....thats generally noted by a huge plume out the tail pipe. For the oil...dont be using something so heavy...the leak is there cause something aint sealing. Heavier oil will mask a problem while creating a new one elsewhere. If you are looking for backup as too the tune-up in a can should fix it idea, You're getting advice from the wrong guy <img src="/forums/images/graemlins/mrt.gif" alt="" /> Find the source of the oil (valve stem seal) and fix it, leave yourself with no worries.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: 22RE smokes blue, white, and brown [Re: axledeep] #312869 09/13/03 03:39 AM
Make sure you pull the valve cover before using ANY motor flush (oil passage cleaner). if the valve cover or head has significant build-up DO NOT use motor flush, it will loosen the crap and it will find it's way into you bearings. this is very bad and will destroy most moving parts in your motor. how do I know this, because I killed my 22RE this way. and only found out when I took it apart to fix t-chain guides. result Total rebuild$$$.....Karl
Re: 22RE smokes blue, white, and brown [Re: Esquire812] #312870 09/13/03 03:53 AM
Frankenyota Offline
I'll back Darin up on the Bg 44K recommendation. It is made by BG Products and sold at some NAPAs and some dealership service depts. Really potent and good stuff. On most vehicles you have to readjust the idle after it cleans all the gunk out of the fuel system, no kidding! It is like $20 a can though, ouch. My bro worked as a mechanic for 8 years and his independant shop used all the BG products exclusively, they make a bunch. Me and my bro both hate additives in general btw, there are a a (very) few good ones, BG and lubeguard being chief among them. Pretty much anything you can get at the auto parts store, except chevron techron are crap though.
1986 4X4, 1991 22RE, 5.71 gears,ARB Rear, aux fuel tank, 3mm O/S TB/intake, engnbldr cam, LCE header, magnaflow w/2.25 exh. custom 4 color paint job :-P 33X12.5 Goodyear MT/Rs
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.012s) Memory: 0.6042 MB (Peak: 0.6790 MB) Data Comp: Off Server Time: 2026-11-19 00:15:24 UTC
