Post deleted by little_joe
#313719
09/11/03 09:33 AM
Re: Fuel Atomizer Installed And Happy
#313720
09/11/03 09:48 AM
Apologies were meant towards HaveBlue, but if no one else was offended thats good too. <img src="/forums/images/graemlins/kewl.gif" alt="" />
A little off subject, but anyone have any bright ideas for keeping the metal spark plug connector connected to the lead when removing the wires. Never fails, when I replace the wires, connector =stuck on plug=B I T C H. <img src="/forums/images/graemlins/angry.gif" alt="" />
#313721
09/11/03 10:02 AM
#313722
09/11/03 10:45 PM
I use AUTOLITE SUREFIT already assembled. You are probably aware that my plugs are 6" deep inside my valve cover. <img src="/forums/images/graemlins/angry.gif" alt="" /> Just enough clearance to get a socket in. They have a plastic extension which houses the connector on top of which sits a rubber plug to seal out the bad stuff. If they made the set-up one piece i wouldn't have this problem. The rubber part slides off the plastic part and the wire comes out with it. I put a gob of dielectric grease in the end of the extension(plugside). They come from the manufacturer with some but not much.
I've seen, I think, STREETWIRES makes a solid one piece unit but not for my truck. If I could get one of those to work that would be great. <img src="/forums/images/graemlins/coolg.gif" alt="" />
#313723
09/11/03 10:55 PM
I've never had this problem with factory wires. Are you trying to remove the boot when the engine is hot? If so the sealant/glue that holds the wires and boots together will be hot and that's probably why you're having problems.
Milan _ _ _ _ _ _ __ _ _ _ _ _ _ Support our troops!
'98 4R Limited '82 Toy 4.3 TBI sold
[Re: FattyCBR]
#313724
09/11/03 11:09 PM
I've never had this problem with factory wires. Are you trying to remove the boot when the engine is hot? If so the sealant/glue that holds the wires and boots together will be hot and that's probably why you're having problems. I like that idea thanks. I'm normally iin a hurry. It always happens when I try to do the job after school and before work...just enough time to get it done if everthing cooperates. They usually don't. "MMMMM...new wires" "DOH...stoopid boots."
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6053 MB (Peak: 0.6734 MB) Data Comp: Off Server Time: 2026-06-07 11:16:53 UTCValid HTML 5 and Valid CSS
