Page 3 of 3 1 2 3
Post deleted by little_joe #313719 09/11/03 09:33 AM
Re: Fuel Atomizer Installed And Happy #313720 09/11/03 09:48 AM
Apologies were meant towards HaveBlue, but if no one else was offended thats good too. <img src="/forums/images/graemlins/kewl.gif" alt="" />
A little off subject, but anyone have any bright ideas for keeping the metal spark plug connector connected to the lead when removing the wires. Never fails, when I replace the wires, connector =stuck on plug=B I T C H. <img src="/forums/images/graemlins/angry.gif" alt="" />
Post deleted by little_joe #313721 09/11/03 10:02 AM
Re: Fuel Atomizer Installed And Happy #313722 09/11/03 10:45 PM
I use AUTOLITE SUREFIT already assembled. You are probably aware that my plugs are 6" deep inside my valve cover. <img src="/forums/images/graemlins/angry.gif" alt="" /> Just enough clearance to get a socket in. They have a plastic extension which houses the connector on top of which sits a rubber plug to seal out the bad stuff. If they made the set-up one piece i wouldn't have this problem. The rubber part slides off the plastic part and the wire comes out with it. I put a gob of dielectric grease in the end of the extension(plugside). They come from the manufacturer with some but not much.
I've seen, I think, STREETWIRES makes a solid one piece unit but not for my truck. If I could get one of those to work that would be great. <img src="/forums/images/graemlins/coolg.gif" alt="" />
Re: Fuel Atomizer Installed And Happy #313723 09/11/03 10:55 PM
FattyCBR Offline
I've never had this problem with factory wires. Are you trying to remove the boot when the engine is hot? If so the sealant/glue that holds the wires and boots together will be hot and that's probably why you're having problems.
Milan
_ _ _ _ _ _ __ _ _ _ _ _ _
Support our troops!
'98 4R Limited
'82 Toy 4.3 TBI sold
Re: Fuel Atomizer Installed And Happy [Re: FattyCBR] #313724 09/11/03 11:09 PM
I like that idea thanks. I'm normally iin a hurry. It always happens when I try to do the job after school and before work...just enough time to get it done if everthing cooperates. They usually don't.
"MMMMM...new wires"
"DOH...stoopid boots."
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6043 MB (Peak: 0.6890 MB) Data Comp: Off Server Time: 2026-06-14 04:01:02 UTC
