A couple questions.. #315274 09/12/03 09:26 PM
j03 Offline OP
If anyone knows...
Just tried to pass emissions but its idling too high. Before I take it in somewhere. Is it just a screw to turn to adjust the Idle or what do I need to do just to turn it down?
Its an 88 Trooper with the 4cyl 2.6L Fuel Injected.
Oh and while im asking questions.. where exactly in the O2 sensor switch.. I replaced the sensor but need to reset the switch. I know its behind the dash.. but is it ON the back of the speedometer?
Thanks!
-joe
90 Trooper 2.6 - AMC head
Re: A couple questions.. [Re: j03] #315275 09/12/03 11:23 PM
L
Lor Offline
Hmm... Not sure about trooper, but the screw for the idle should be around the intake. Mine is on the top looking from the back of the engine (sorta). It's a big (about dime size or a tad smaller) flat head screw.
To reset the computer, just unplug the battery for a minute should do it.
Well, hope the more experienced fellows here will answer your question.
Re: A couple questions.. [Re: Lor] #315276 09/13/03 12:27 AM
j03 Offline OP
Thanks, Im going to go take a look at that.
Im pretty sure its not possible to reset the O2 sensor from the battery.. cos it has been disconnected recently.
Re: A couple questions.. [Re: j03] #315277 09/13/03 01:25 AM
lttlbddy Offline
I was told that there is a switch on the back of the dash, not sure where.
On the Amigos you have to take instrument cluster out and move a screw from one hole to another to reset.
Sorry I can't give you better info.
Try using the search feature search for 'O2 sensor'
Steve G
1990 Amigo XS 4x4, BFG MT 35s, Front & Rear ARBs, 5.38s, Tera Lows, custom springs, custom nerf bars, DOR Front Bumper, custom rear bumper, HD 9500 winch, some CalMini & other stuff
Re: A couple questions.. [Re: lttlbddy] #315278 09/13/03 01:28 AM
Canucklehead Offline
Try this link.
http://forum.planetisuzoo.com/viewtopic.php?t=196
Steve
'97 Rodeo 5spd. 3.2L SOHC V6 4WD
PHP: 7.4.33 Page Time: 0.022s Queries: 15 (0.017s) Memory: 0.6057 MB (Peak: 0.6705 MB) Data Comp: Off Server Time: 2026-11-19 00:14:09 UTC
