Page 3 of 3 1 2 3
Re: Seatbelt Warranty 60K [Re: hogula] #315622 09/18/03 04:07 AM
ErikB Offline
Toyota Moderator
Its all in GARYM's post on 9/16!!! <img src="/forums/images/graemlins/nana.gif" alt="" />
http://home.4x4wire.com/erik
Re: Seatbelt Warranty 60K [Re: ErikB] #315623 09/21/03 07:04 PM
ArbitraryNotion Offline
Here is the link to my writeup....
Seatbelt writeup
Have fun and don't let go of that center peice!!!
1986 Toyota 4x4 22wEBer
Ported EB Offroad H/O Head "Josh Cam"
Ported Intake & Weber38mm Carb
LCE Header & 2.25in Exhaust
RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
Re: Seatbelt Warranty 60K [Re: ArbitraryNotion] #315624 10/13/03 08:32 PM
Kookadala Offline OP
Did the seatbelt mod when I had them removed during the body lift. They actually work alot better now. The passenger side was tricky as the autobrake mechanism is different. I had to drill a small hole in the plastic housing and hold the stop tab down to allow the cam to pass when tightening the spring. This will make sense if you try the mod. I also soaked the belts in soapy water for a day to clean them up, as I could not remove the drivers side from the mechanism due to the small slot. I definately recommend this mod. Its a lot cheaper then replacing the belts.
96 T100 4x4 - 35's, 4" SL, 2" BL, 4.88s, ARBs, custom bumper & E9000 winch, etc.
99 F-350 4x4 superduty supercab turbodiesel longbed
Re: Seatbelt Warranty 60K [Re: garym] #315625 03/31/04 09:31 PM
Hi
If not too late, would you email me with seat belt instructions. Recently purchased a '96 t100 extra 4x4 with the common belt problem.
Thanks
Bob C
email: db7004@snet.net
Re: Seatbelt Warranty 60K #315626 03/31/04 10:08 PM
Hey, just two posts up from yours is a weblink to the directions, you can print them from there.
Re: Seatbelt Warranty 60K [Re: Kookadala] #315627 04/09/04 06:50 PM
cymmgarcia Offline
In case anyone has been putting off the seatbelt replacement due to all the disassembly there is an easier way!
I just did it yesterday by removing the door sill trim and the lower front seatbelt anchor. I then very carefully flexed out the back side panel plastic at the lower front corner to have just enough room to unbolt the racheting mechanism. I removed the belt, wound up the spring and put everything back together.
It helps if you do this on a hot day so the plastic is more flexible. I live in Miami (88 yesterday) so it was not a problem!
Good luck to all,
Candido
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6158 MB (Peak: 0.6852 MB) Data Comp: Off Server Time: 2026-06-21 11:14:49 UTC
