FJ80 Rear in Mini #31570 04/17/02 05:51 AM
Kendall Offline OP
I am thinking of putting a FJ80 rear end in a mini truck. I know that the diff is offset to the passenger side. Will a offset diff work with a centered transfer case output? There may be clearance issues with the gas tank, but that can be moved.
I found a set of FJ80 axles with elockers for $900. Is this a good price?
What do you think?
88 Xtra Cab, SAS, 35X12.50 MTR, Toyota E-Lockers front and rear, Rear seat, custom nerfs and rear bumper.
Re: FJ80 Rear in Mini #31571 04/16/02 10:48 PM
If you're willing to move the tank, go for it! Plan on running a CV rear driveshaft, that should take care of the compound angle.
Wider, stronger axles, dual E-lockers, cool stuff.
$900 sounds like a deal to me if both ends have lockers.
Re: FJ80 Rear in Mini #31572 04/17/02 03:44 AM
Sounds like a great price.
Re: FJ80 Rear in Mini #31573 04/17/02 04:32 AM
Josh Offline
Sounds like a horrible deal to me, please forward the contact info my way <img border="0" title="" alt="[Wink]" src="images/icons/wink.gif" /> <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
Josh
01 Chevy 2500HD: 6.0L gas 4x4 crew cab
in search of the next trail rig
Re: FJ80 Rear in Mini #31574 04/17/02 10:30 PM
ErikB Offline
Toyota Moderator
I'd think you'd have to use a NON-CV driveshaft.
With a CV shaft, the pinion has to be pointed at the t-case, which isn't going to happen w/ an offset diff.
With a non-CV shaft, the flanges just need to be parallel, which can happen w/ an offset diff...
... however this is just "in theory." <img border="0" alt="[Nerd]" title="" src="graemlins/nerd.gif" />
http://home.4x4wire.com/erik
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.5956 MB (Peak: 0.6571 MB) Data Comp: Off Server Time: 2026-06-25 12:15:37 UTC
