Page 3 of 3 1 2 3
Re: Has anyone replaced our traction bars? [Re: StinkBug] #320729 10/06/03 02:39 AM
paulevans76 Offline
RE, johnny joint, whatever. you know what I meant <img src="/forums/images/graemlins/cheers.gif" alt="" />
88 Troop - Posing yard art
Re: Has anyone replaced our traction bars? [Re: paulevans76] #320730 10/06/03 03:09 AM
StinkBug Offline
well there are some differences,Heims would require a number of spacers to make the factory bracketry fit, Johnny joints are pretty similar to the RE except that they have a pair of poly bushings in them that can get worn out, whereas the RE has delrin bushings that reduce the play and dont wear out as fast, and can be easily replaced. There are good points to all of them, but i'm fairly partial to the RE. I'm still waiting to get Gilberts trooper over to my shop again so I can take some measurements to see if the RE joints will fit in the factory mounts. I'm hoping that the metric bolt size Isuzu uses is either close enough to a 9/16", or that its smaller and the holes in the brackets can be drilled to fit.
[color:"blue"]Crew Chief, RedBull RockCrawling Team [/color]
[color:"red"]StinkyFab Custom Metal Creations[/color]
Project StinkBug
Re: Has anyone replaced our traction bars? [Re: StinkBug] #320731 10/06/03 03:16 AM
rubo Offline
Hey Stinky did you get my PM?
rubo
"If i can't crawl over it, i'll fly over it"
rubo
'96 Amigo 4x4, 3.2L V6, 4L30E, D44 rear, SOA, 1" BL, undergoing surgery.
'00 Rodeo LS 4x4, 3.2L V6, OME 919 Springs, front cranked to match,1" BL, 265/70x16 Scorion A/T's.
Re: Has anyone replaced our traction bars? [Re: sveltax] #320732 10/06/03 03:37 AM
Bansil Offline
In ref. to "traction" bars you will not bend the upper ones.
The lower yes they need some beefing.I replaced my upper driverside with a modified/fab'd stock bar it is the sh--!
I clear my tank,crossmember,and can flex more than mounts
will allow.Helms(loud) or J/J etc. are next as well as
new shock mounts and a locker to let the flex work.
The discusion between upper/lower arms/links are two
totally diff. discusions with different end results
1)the uppers let it flex
2)the lowers need to not bend/smash etc.
My .02
Doug
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: Has anyone replaced our traction bars? [Re: rubo] #320733 10/06/03 04:40 AM
StinkBug Offline
rubo
OOPS! i just got it sorry. The "you've got mail" blinking icon really needs to be bigger on here <img src="/forums/images/graemlins/smile.gif" alt="" /> I'm blind. PM'd you back.
Dallas
Project StinkBug
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 3.831s Queries: 16 (0.007s) Memory: 0.6136 MB (Peak: 0.6950 MB) Data Comp: Off Server Time: 2026-11-15 15:30:29 UTC
