Not Starting...Low idle Any Ideas...Please! #321993 09/27/03 04:56 AM
TLB Offline OP
My ride is having some issues, here's whats going on with my 99 Rodeo 3.2 auto 4x4...It has ran perfectly until today. Went for a drive to the hills, noticed sluggish acceleration and poor performance on hills (paved) even with power mode on. After stopping and taking a break, went to leave truck would start and die. Did this three times until I kept it revved enough to stay running. On the way home it remained running even at stops, however it idles at about 500rpms now. I had autozone try to pull trouble codes, no codes were found. The intake manifold gasket has been replaced already. I'm at 50,000 miles so any ideas as what to look for would be greatly appreciated.
Thanks
Tim B.
99 Rodeo
Tim Barlow
05' Sequoia SR5
98' 4Runner SR5
Re: Not Starting...Low idle Any Ideas...Please! [Re: TLB] #321994 09/27/03 05:35 AM
Try cleaning the IAC, be careful and do not push/pull plunger. Also may want to check the fuel filter.
Re: Not Starting...Low idle Any Ideas...Please! #321995 09/27/03 08:41 PM
TLB Offline OP
After checking every possible thing, it appears some really bad gas is the culprit. By the way what is the IAC, sorry for the inexperience, but thanks for the ideas.
Tim B.
Tim Barlow
05' Sequoia SR5
98' 4Runner SR5
Re: Not Starting...Low idle Any Ideas...Please! [Re: TLB] #321996 09/28/03 03:59 AM
IAC= Idle Air Control Valve It can cause some problems if it malfunctions, it can get carbon build up on it. Glad to hear you got the problem solved. You may still want to think about changing the fuel filter, it is pretty easy, at least on the 98, no special tool needed.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5926 MB (Peak: 0.6520 MB) Data Comp: Off Server Time: 2026-06-24 09:41:12 UTC
