Why won't my truck charge the battery?
#324335
10/02/03 02:46 AM
'84 4Runner - I've got just over 12 volts at the battery (freshly charged) with truck running (or not). I have now installed 2nd new alternator and voltage regulator. I have new cables, good ground to fenderwell and block, good fuses, open line (no resistence)on any wire between alt and VR, belts are good... My CHARGE lite and BRAKE lite in dash used to "flicker" together before they both started staying on. I travel alot, and have resorted to dual cycle batts, charging them when I stop and switching them when the lights get too dim to drive.
Where else can I look for a problem?
Jason
1984 4Runner - V6 rear axle (locked by Lincoln), header, plenty of body cancer! Waiting for install: x-over steering, dual 'cases, twin-stick, 3" body & drivetrain lift, rear springs up front Still need: rear springs, 35" MT's, bumpers/sliders 2001 F350 - 7.3 110k miles on WVO conversion now!
Re: Why won't my truck charge the battery?
[Re: airfooter]
#324336
10/02/03 02:56 AM
when the truck is running you should measure 14 volts or higher at the battery posts.
if not, the alternator aint doing its job...
check the belt. it is "tight" enough?
measure the voltage at the post of the alternator. then at the battery. voltage drop should be very small.
but again, alternator should be putting out 14 or more volts...
leo d. 90 4runner, v6, auto, WCOR CitB kit, marlin duals, arb rear, tt front 4.88, blah, blah, blah... Pres. of TEAM IFS! and GETTING OFF 4WD Club member
[Re: ldivinag]
#324337
10/02/03 03:04 AM
Not being a sparky, I had a like problem that turned out to be a solenoid, replaced everything but... of course that was on an old small block Ford years ago. Electrical things are a pain and sometime worth having a pro do it. Some parts stores advertize that they will check you charging system for free...
[Re: ldivinag]
#324338
10/02/03 01:38 PM
Belts are tight. No wires are broken either. There are 4 wires on my alternator. Anyone know what voltage to check for? Advance Discount Auto parts "checked" my charging system and said it did not work (their "machine" is a voltmeter/ammeter). They could not tell me if it was alt, volt. reg. or something else. Since alt and vr were "lifetime" they just gave me new ones. I am kicking myself for not having them bench test the old one... (I talked parts dude into letting me take new one home and change it, and then brought old one back). Oh yeah, while visitng my dad, he insisted we unhook the battery to see if truck still runs... After replacing Igniter, several fuses and ruining my aftermarket tach (read a couple hundred bucks total), I now know why they always said this is a BAD IDEA!
[Re: airfooter]
#324339
10/02/03 02:14 PM
sounds like it's charging now.
[Re: airfooter]
#324340
10/02/03 06:31 PM
Yup, never a good idea to let the magic smoke out of any electrical component. No more smoke...no more work. <img src="/forums/images/graemlins/notooth.gif" alt="" /> I tend to bring the spark outta electrical things myself...man does it hurt. Both physically and financially. Hope dad at least sprang for some steaks and beers after your little adventure. ~Darin <img src="/forums/images/graemlins/baby.gif" alt="" />
88' 4x4 *22R-EB Gen II* 87' $Runner *22R-EB Gen I* 85' Sillyca 22R-Esq  "I LIVE IN MY OWN WORLD...THEY KNOW ME WELL THERE"
[Re: Esquire812]
#324341
10/02/03 09:37 PM
Toyota Section Staffer
Common mistake, that 'remove the battery from the circuit' trick. 'Gee, it worked on my '66 Fairlane!'
As a Dad, lemme say to him: You are on the hook for your kid's parts, man.
-Bill '87 4Runner w/ '96 5VZ-FE, 'Red Chili II' '97 Taco XtraCab 3RZ-FE, 'BlackBean' TLCA # 13257, Rising Sun 4x4 Club Land Use Coordinator "He who stops being better stops being good." -Oliver Cromwell
[Re: Red_Chili]
#324342
10/02/03 09:44 PM
Dang kids is expensive arent they! lol Now when it comes to vehicles the whole family comes to me, but my stepson is into guitars etc. I wont even hold em let alone start messing with all them electronic buttons, dials and thingy-majiggies. His last guitar cost over $1000...what ever happened to them bigassed box kind ya didnt have to plug into a substation to play..ya know like the kind Elvis played! hehehe
*Hey airfloater, did you say you replaced the regulator thingy? Pretty sure 84' had an exterior regulator right...kinda like a big black heavy box thing? If you havent tried that see about a replacement. I had a nissan thats electrical was all FUBAR'd and the regulator would test out fine. When in all reality it was until it warmed up then sent stray currents all over hell. I shoulda bought stock in BUSS fuses back then...used to carry multiple boxes of varied sizes just incase I had to use a turn signal hehehe. If you need a regulator for testing purpose give me a yell..I have one from an 86' parts lot I acquired. ~Darin <img src="/forums/images/graemlins/baby.gif" alt="" />
[Re: Esquire812]
#324343
10/02/03 09:48 PM
Wow Darin, are you sure you aren't too old to drive? <img src="/forums/images/graemlins/lol.gif" alt="" /> lol. Them there electronics need lotsa learnin. <img src="/forums/images/graemlins/cheers.gif" alt="" /> .
(Sorry, I just couldn't resist)
(aka suprathepeg, aka Sean) 89 v6 SWB truck "BLACK BEAUTY" EB valves, P&P head 30 over. 95 FZJ80. Lifted. locked and rollin on 33s (my dream machine)
[Re: Rauch_Off_Road]
#324344
10/02/03 09:53 PM
Supra.... <img src="/forums/images/graemlins/bird.gif" alt="" />
LOL - Hey man I'll be 32 in November...step son is 16 you do the math. Mama is just a bit older. Gotta love our life situation, the boys dad is giving us the rims off his 98' 4Runner (16" baby!!) that he recently sold when he bought his 03' Tacoma double cab with S/C'd 3.4L. And we get along great...I get to drive the Taco this weekend! <img src="/forums/images/graemlins/nana.gif" alt="" /> hehehe
