2 easy Questions for the pros #325302 10/03/03 07:53 PM
A
axledeep Offline OP
1985 22re
#1 - My oil dipstick is really loose in the distick tube (I guess from the rubber seal shrinking with age). I know this is a common occurance on older motors *jeesh...starting to sound like a Viagra commercial <img src="/forums/images/graemlins/ignore.gif" alt="" />*. Can this cause any problems like low oil pressure? My truck reads lowish oil pressure and I'm wondering if that could be why. Are there any fixes short of buying a new dipstick?
#2 - The A/C idle adjust screw thingy. You know, the plastic screw with the spring on it attached to side of the intake manifold. I have removed my a/c compressor and don't intend to ever run a/c. How should I set this screw? Should I close it all the way....open it...or what? Any ideas?
Thanks folks <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 2 easy Questions for the pros [Re: axledeep] #325303 10/03/03 08:01 PM
Your dipstick wont have anything to do with your oil pressure. Cant tell you about the other, dont have AC smile
Re: 2 easy Questions for the pros #325304 10/03/03 08:07 PM
A
axledeep Offline OP
My thought was that with the bad seal caused my the loose dipstick, pressure wouldn't build up like it should......... <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: 2 easy Questions for the pros [Re: axledeep] #325305 10/03/03 08:17 PM
Happy Birthday Esquire812 Offline
Dipstick wont have an effect on oil pressure...but will let you know if your rings ever go bad by shooting itself out of the tube!
If you dont intend on reinstalling the A/C and if the truck doesnt have PS then pull the valve off and use a plug in the plenum. My 88' which is A/C and PS free just has the standard bolt style plugs in the unused vaccum holes. Quick question for ya....do you happen to have the A/C VSV still??
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: 2 easy Questions for the pros [Re: axledeep] #325306 10/03/03 08:21 PM
Brown Offline
Oil pressure is a result of the clearances in the oil pump and the crankshaft. The dipstick tube having a seal or not will not affect the oil pressure in any way.
Is there a vacuum line going to that adjustment screw-- I can't remember??? <img src="/forums/images/graemlins/confused.gif" alt="" /> If there is, then all I think you would have to do would be to plug the line, and then you won't have to worry about adjusting that screw.
Jeremy
SOLD:[color:"666666"]1988 Toyota 4x4 | 22RE | W56 | EB 270 cam [/color]
Re: 2 easy Questions for the pros [Re: Esquire812] #325307 10/03/03 08:23 PM
Brown Offline
You are too quick on the draw, Darin. <img src="/forums/images/graemlins/bird.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Jeremy
Re: 2 easy Questions for the pros [Re: Brown] #325308 10/03/03 08:26 PM
<img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Huh? Whatchya mean? lol Im totally new all these rich people creature comforts. The 4Runner has both A/C and PS and Im learning about both systems really quicklike. Unfortunately the dumbasses that fixed the PO motor for her, got rid of almost every vaccum related component when they halfassed it and ditched the EFI for a carb. You would never believe this thing ran based on what was under the hood <img src="/forums/images/graemlins/rolleyes.gif" alt="" />.
85' Sillyca 22R-Esq
Re: 2 easy Questions for the pros [Re: Brown] #325309 10/03/03 08:29 PM
4Crawler Offline
Won't matter on the A/C idle up, if the VSV is never energized, the idle up valve will never open and nothing will happen. On my (currently) inoperative A/C, I just disconnected the compressor clutch wire, jumpered the low pressure switch and voila, a push button fast idle circuit, hit the A/C button and up comes the idle speed. Turn the plastic knob up or down to set the desired speed.
If you want to remove it all together, jut cap off the vacuum lines at each end and pull the VSV.
Re: 2 easy Questions for the pros [Re: 4Crawler] #325310 10/03/03 08:31 PM
And send it to ME! lol
*And although not a pro, I have sometimes played one on TV! <img src="/forums/images/graemlins/pfft.gif" alt="" />
85' Sillyca 22R-Esq
Re: 2 easy Questions for the pros [Re: axledeep] #325311 10/03/03 09:02 PM
Brown Offline
OH, and btw, I am not and don't claim to be a pro <img src="/forums/images/graemlins/evil.gif" alt="" />... but I thought I might be able to help. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/nana.gif" alt="" />
Jeremy
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.011s) Memory: 0.6397 MB (Peak: 0.7643 MB) Data Comp: Off Server Time: 2026-11-19 05:09:16 UTC
