Center bearing and double cardan joint
#328768
10/09/03 01:56 PM
I'm fighting a driveshaft vibration problem and looking at the center bearing and double C as the culprits.
Can someone tell me how to check the center bearing? I can grab the driveshaft and move it from side to side a bit. It does not have any loose slop. The rubber cushion just gives and allows it to move. Is this normal? How much movement is allowed?
Any advice on how to check the double cardan joint would be appreciated as well. I plan on disconnecting the shaft and looking at the joint closely on a bench. I don't see any slop in the joint at all but it could be binding.
Thanks,
Shedman
97 T100 4x4 SR5 Extra cab Automatic 3.4L engine
Re: Center bearing and double cardan joint
[Re: Shedman]
#328769
10/09/03 02:46 PM
Slight movement from the rubber is normal. The way I check for worn parts in the drive shaft is to rock the truck back and forth by hand with it in park or in gear (engine off). The rocking motion will show any back lash in the u-joints. Look for any movement of the inner sleeve inside the bearing caps of the u-joints.
John
John Luttrell 2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5871 MB (Peak: 0.6353 MB) Data Comp: Off Server Time: 2026-06-23 12:50:05 UTCValid HTML 5 and Valid CSS
