'90 Montero clicks but won't start (or turnover) #328818 10/09/03 05:01 PM
1990 Montero ... I've got good power from a new battery, but when I turn the key all I hear is the click of relay's behind the dash ... nothing from the engine or starter though ... I thought this might be a bad engine control relay? ... or possible the solinoid on the starter? ... this has happened 3 times ... first 2, it suddenly "fixed" itself after a couple of hours (and some bad language), then worked fine for about a week ... now it hasn't fixed itself this time. Any ideas of what it could be?
Re: '90 Montero clicks but won't start (or turnover) #328819 10/09/03 08:43 PM
Try hitting the starter with a hammer (seriously) a few times. Be careful to avoid hitting the solenoid (piggy backed on the starter).
If she starts afterwards, then you know what's wrong.
Ray
Re: '90 Montero clicks but won't start (or turnover) [Re: off-roader] #328820 10/09/03 09:47 PM
pmontero Offline
Get a copper brush, remove both battery terminals from the battery and clean both terminals and posts inside and out. Also, separate the fusible link box from the positive battery terminal and clean that connection well too. Put everything back together and try again. If you still have the problem than it's either the starter (see Offroader's post) or it could be a bad battery cable or connection at the starter.
It's not likely an engine control issue. The starter is hotwired directly to the battery along with the ignition switch.
Good luck,
Powell
'87 Montero Diesel
'98 Porsche Boxster Electric
and more...
Greasology
NotPetroleum
Re: '90 Montero clicks but won't start (or turnover) [Re: pmontero] #328821 10/09/03 10:09 PM
sparkem Offline
Try starting in Neutral. If it works, it might be the switch, i forgot the name, that stops it from starting if in anyother selection other than Park and Neutral. Or switch may need to be cleaned. Good luck.
Re: '90 Montero clicks but won't start (or turnover) [Re: sparkem] #328822 10/09/03 11:10 PM
Neutral Safety Switch.
You sometimes need to jiggle the shifter back and forth between neutral and park.
Switch may also have come loose.
Ray
Re: '90 Montero clicks but won't start (or turnover) [Re: off-roader] #328823 10/09/03 11:55 PM
DaphneD Offline
Sounds like corroded battery terminals. That's what my problem was the last time that happend. The time before that it was the starter. The time before that it was corroded battery terminals...
You've already got good advice to help with those. Good luck! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Let us know what works. We love feedback! <img src="/forums/images/graemlins/smile.gif" alt="" />
'89 Raider 3.0L V6 (6G72) w/ AW372L (A44DL) A/T
"The Millennium Falcon of automobiles"
Re: '90 Montero clicks but won't start (or turnover) #328824 11/10/03 03:06 PM
carbonbody Offline
Help! I'm buying a Monty that is doing the same thing. I can hear one click of a relay, then if i fiddle with the neutral switch i can get another relay to click. Nothing clicking at the starter. I have new battery and termials.
Did you find out what was causing your problem?
thanks
Re: '90 Montero clicks but won't start (or turnover) [Re: carbonbody] #328825 11/10/03 03:57 PM
BottomFeeder Offline
Mine does this sometimes. It is the starter in my case. Just give it a couple of taps and mine will start right up. The other option to think about is your computer.
1990 Montero LS "Bottom Feeder" LWB, 33's, Cheapass Lift, 2" body lift, Dual BoUnCyS, Dual LSD's, KC's.
1995 Montero SR Complete LS interior swap and a BoUnCy from a 96 SR. General Grabber AT2's 33X12.5. 1.5" Body Lift
Re: '90 Montero clicks but won't start (or turnover) [Re: BottomFeeder] #328826 11/10/03 04:27 PM
DougH Offline
Mitsubishi Forum Moderator
To test the operation of the starter you can bypass the ignition switch, nuetral saftey switch, and everything else by running a wire from the positive terminal of the battery. You take this and jump the terminal on the starter solenoid. This is the unit that is attatched to the starter. This should start the truck right up. If it doesnt, then you have a problem with: your grounds, your starter, or your solinoid.
Just becarefull to make contact at the solinoid, and not at the starter (the bigger terminal), if you jump the starter only you will not properly engage the bendix? and you can damadge you fly wheel or flex plate.
DougH
1995 SR - RIP
1993 RS - RIP
Re: '90 Montero clicks but won't start (or turnover) [Re: DougH] #328827 11/11/03 03:33 PM
carbonbody Offline
My problem was the starter. Tapped it with a hammer, it fired up. But...it only worked once. Had to replace the starter. $180 - $50 core from AutoZone. Had it running in 30 mins. This is my first Monty and I love it. I had a '90 trooper, but the Monty is faster, smooter, and i love the bouncy seat. smile
Now to find some cool stuff for it.... like brush guard and roof rack!
jason in NC
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.005s) Memory: 0.6399 MB (Peak: 0.7642 MB) Data Comp: Off Server Time: 2026-06-17 01:31:03 UTC
