MUA tranny/t-case guru's - need input
#331734
10/15/03 06:58 AM
94 rodeo, 3.2, 5spd, 50k miles on clutch.
While wheeling this past weekend, I had my truck bail out on me. I would be cruising along in 4lo, either 1st or 2nd gear and then all of a sudden the truck would just stop forward progress completely. There would be that funky clutch slippage smell. I'd pop it in reverse, back up some, put it back in 1st and it would barely move forward. After a few tries it would eventually pull itself.
The first time I was on a 15-20% grade, nothing major. Later that night I removed my shifter boot because I thought the boot was pushing the t-case into that neutral region between 4lo and 4hi. Next day everything was going fine, but it happened once again. This time on less of a grade. I had just finished climbing a nasty hill, so I didn't want to back down it.
I packed it up after that, thinking it was definitely the clutch. Got back to camp, hooked my trailer up and headed home. No slippage in 2wd even with the trailer in tow. Looking back I wish I had thought to stick it in 2hi or 4hi to see if the problem was still there.
BTW - I know I wasn't just spinning because I was watching both my tires on the driverside and my truck is locked front and rear. The second time I was also looked down to see the front driveshaft was not turning.
Now for the question: For those of you who know the ins and outs of the isuzu t-cases, is there any linkages or known problems that I should look for? My rodeo is 150 miles away from me right now, so tearing it apart will be a ways away, but I'd like to know what I'll be getting into.
TIA
-chris
94 Rodeo, 35's, 5.38's, locked F&R, Rocker bar on one side, other side in garage
96 Tacoma, DD, pre-dented
Re: MUA tranny/t-case guru's - need input
[Re: rodeo_chris]
#331735
10/15/03 08:27 AM
Isuzu Moderator
Bottom line? If it is the tranny, just find a good used one. Rebuilding or paying for someone to rebuild is an expensive route. Parts are expensive and there are several special tools needed. While there are people who rebuild trannys, finding one who is familiar with Isuzu boxes will prove to be almost impossible.
Now, let's figure out what is wrong. Fluid levels? What are they? Fluid condition and type? Might as well drain it and check the drain plugs. Clutch master and slave conditions? Fluid levels in each? Rear main condition?
There are not many things that could go wrong and still give you 2wd. RobG welded his 4wd gear to the mainshaft via the needle bearings because of massive fluid loss from the transfer case. That stopped things cold. If it was gear related, I would suspect you would have heard it before things got bad.
Other things to look at. Front drive shaft u-joints. If they are dry or dead they could bind enough to cause some issues (grasping for straws here). You say you are locked in the front. How? Lock-Right or Lincoln? Is it possible for the front end to have self-destructed?
That is a good place to start. You said you smelled clutch slippage, but you need to find out if that is the actual problem, or a result of a tranny issue.
Good Luck, Michael
[Re: mlclark]
#331736
10/15/03 11:36 PM
I changed the fluid not too long ago, but I'll drain them both next time I go home. There are not many things that could go wrong and still give you 2wd. RobG welded his 4wd gear to the mainshaft via the needle bearings because of massive fluid loss from the transfer case. That stopped things cold. If it was gear related, I would suspect you would have heard it before things got bad.
I also plan to pull the rear half of the t-case off when I get a chance to see if I can see anything obviously wrong in there. Probably wont get a chance until Christmas break. Other things to look at. Front drive shaft u-joints. If they are dry or dead they could bind enough to cause some issues (grasping for straws here). You say you are locked in the front. How? Lock-Right or Lincoln? Is it possible for the front end to have self-destructed?
Front shaft looked ok, I'll double check. Lock-right in the front, No-Slip in the rear. Self-destructed front axle should have had more problems than what I'm experiencing. I just got my 5.38's put in there, they've got around 200 4wd miles on them. That is a good place to start. You said you smelled clutch slippage, but you need to find out if that is the actual problem, or a result of a tranny issue.
I'll consider a new clutch, but due to a major lack of funds, as long as it seems to be pulling fine in 2wd, I can't justify the added expense right now. -chris
[Re: rodeo_chris]
#331737
10/16/03 01:22 PM
There is nothing in the MUA5 to slip- if it was a 4WD problem you should have had some grinding or something. I assume that you didn't just have trouble with it popping out of gear.
Sounds like clutch slippage to me. How old is it?
