Where to get a switch that fits the Toyota slots #331980 10/15/03 07:58 PM
I installed a air horn and have it running to a switch, where can I get one that fits the slots on the left of the driver side so it fits flush in the dash.
Re: Where to get a switch that fits the Toyota slots #331981 10/15/03 08:13 PM
bard Offline
Local Toyota parts dept.
Re: Where to get a switch that fits the Toyota slots #331982 10/15/03 08:30 PM
the switch from the dealer is for lights, dunno how well it will work for a horn.
Re: Where to get a switch that fits the Toyota slots #331983 10/15/03 09:35 PM
Kajo Offline
http://www.colehersee.com/catalog_top/index.htm
cole-heresee has several switches to choose from. I have used them for my on-board air and my in cab winch mount. I can not remember the part numbers though but they fit perfectly in the slots of my 85. if you know the part number you can order them from most marine stores. I bought my switches at West Marine
Re: Where to get a switch that fits the Toyota slots #331984 10/16/03 04:21 AM
Why would it make a difference?
Re: Where to get a switch that fits the Toyota slots #331985 10/16/03 07:24 AM
Some switches may be rated at a different amp. than others. If too much current is run through a low amp switch, some nasty results could come to be. Other than that, it shouldn't matter much.
Re: Where to get a switch that fits the Toyota slots #331986 10/16/03 02:43 PM
DO NOT GO TO THE STEALER!!!
The dealer actually sells the cole-heresee swtich. For you non-believers read the side of the switch that came from the dealer.
Go to www.westmarine.com and buy the same switch for 4-7 dollars. They work and look great, they even have some that have illumnination in the middle when the switch is on, and you can get different color inserts for different switches.
Re: Where to get a switch that fits the Toyota slots #331987 10/16/03 03:43 PM
mt_goat Offline
If anyone knows the part number for that please post it.
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: Where to get a switch that fits the Toyota slots #331988 10/16/03 08:18 PM
TRDSR5 Offline
these fit also:
Painless switches
Turn LEFT to go RIGHT
Thudump!....What was that daddy? Ran over a Honda, go back to sleep sweety.
Re: Where to get a switch that fits the Toyota slots [Re: mt_goat] #331989 10/16/03 09:11 PM
All of these should fit:
http://www.westmarine.com/webapp/wc...p;catalogId=10001&productId=8147
For a horn I would use the momentary SPST 2 blade #192189 CH#58027-02BP
PHP: 7.4.33 Page Time: 2.440s Queries: 16 (0.004s) Memory: 0.6268 MB (Peak: 0.7477 MB) Data Comp: Off Server Time: 2026-06-19 14:28:32 UTC
