Re-torque 2.6? #333537 10/18/03 07:57 PM
hfoobe Offline OP
My engine has about 12000 miles on it now. Rebuilt block, AMC head. I just read a post that said to re-torque the head bolts and set the valves every 12 to 15000 miles. Is this correct? If it is, do I tighten the head bolts at running temp or cold? I believe the valves get set cold.
Re: Re-torque 2.6? [Re: hfoobe] #333538 10/18/03 08:17 PM
mlclark Offline
Isuzu Moderator
I've never read anything pertaining to re-torquing the head. The factory manual does not call for it. Also some gaskets are not supposed to be re-torqued, like the Fel-Pro Perma-Torque.
For what it is worth, some engines do require a re-torque, just not the 2.6.
As far as valves, every 10-15K is crucial.
Good Luck,
Michael
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5846 MB (Peak: 0.6325 MB) Data Comp: Off Server Time: 2026-06-18 02:36:30 UTC
