94 22RE EFI intake manifold
#335295
10/22/03 05:55 AM
I just acquired that later style intake and wanted to know what is required to fit this to my 85 EFI 22RE. Can I just swap in the upper plenum and my throttle body? Or is it better to swap the whole assembly. I see that the TPS is different. I have a rectangular plug and the newer one is oblonged. Thanks Danny
1985 SR5 4Runner eLocked with Carter Lock 4.7:1 single case Davez Offroad twin stick
Re: 94 22RE EFI intake manifold
[Re: toyrunner]
#335296
10/22/03 03:41 PM
Hello, is anyone out there? Just nod if you can hear me? Is there anyone at home? <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: toyrunner]
#335297
10/22/03 04:15 PM
Toyota Moderator
This is the best writeup I have found: http://home.comcast.net/~jonmarkstewart/85xcab.htm#plenum I used the whole plenum- upper, lower, and the later throttle body. I *think* that you can use the older lower plenum but you have to use the newer upper and throttle body in order to ditch the external Air Flow Valve.
[Re: toyrunner]
#335298
10/22/03 04:40 PM
The link Harry posted will explain everything and the new plenum will bolt right on to your existing lower intake.
[Re: toyrunner]
#335299
10/22/03 04:59 PM
Hi ya Danny! Here is a link I have on the subject: http://www.pirate4x4.com/forum/showthread.php?s=&threadid=63448 ... filter through the usual POR BS for some possible insight. I have one of these late model intakes too but haven't swapped it in yet because I don't have the late model throttle cable. I heard one person say that they were able to use their existing throttle cable but that it was really tight. I didn't like the sound of that. I think that the only real benefit of this swap would be the simplified throttle linkage and hopefully that will translate to a smoother and easier to push gas pedal. I know how nice and smooth your gas pedal is right now... <img src="/forums/images/graemlins/shiner.gif" alt="" />
[Re: carter]
#335300
10/23/03 03:44 AM
Thanks for all the replies ya'll. I was about to give up and look on my own <img src="/forums/images/graemlins/notooth.gif" alt="" /> Is there really any positive result that would warrant such a swap? I'll look at the threads now! Danny
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6095 MB (Peak: 0.6802 MB) Data Comp: Off Server Time: 2026-05-25 23:11:27 UTCValid HTML 5 and Valid CSS
