Donor for SAS
#336180
10/23/03 11:18 PM
What would be the best vehicle to get the axle from to do a Sas? Is it better to go coil sprung or leafs? I'm thinking about gathering parts and was just curious which way to go?What else should I look for? Thanks Mike
'93 Trooper Ls
Re: Donor for SAS
[Re: mike_dup1]
#336181
10/24/03 03:10 AM
If you hit up the search option in the top you'll see many of the trials and tribulations of the dozen or so guys who have done this. And you won't have to wait for an answer.
I'm not one of them, but I have noticed late 70's Wagoneer axles are frequently used, the specifics, you will find easily in past threads.
CHRIS 98 Amigo, 92 Pup
Re: Donor for SAS
[Re: CPOM]
#336182
10/24/03 04:08 AM
1974 to 1976 Jeep Wagoneer.
This is the Dana 44 that has passenger side differential and these years I believe both knuckles were flat top. The passenger side being flat top will be of vital interest to you for steering.
1977 to 1979 Jeep Wagoneer and you can buy my extra passenger side flat top knuckle. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Donor for SAS
[Re: mike_dup1]
#336183
10/24/03 04:23 AM
What would be the best vehicle to get the axle from to do a Sas? very broad question to answer, there are many choices, and what you want to accomplish will determine this. Remember, there is no guide to SAS and every one is different. Give us some details, and go from there. If you don't know yet, you got a lot of reading ahead of you before you need to worry about parts. but the quick answer: 70's Jeep Wagoneer or 80's Toyota solid front axle. Is it better to go coil sprung or leafs? Again, depends on what you are trying to accomplish. But i would say if you are asking this question, stick to leafs. A leaf setup will be far more forgiving as far as design goes and take a lot of headache out which many first time SAS'ers don't want to deal with. -Rob
Robert Gorrell 1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 38x13 TSLs, spooled D60 front, 14bff rear locked by detriot, high steer w/ hydro, dual Isuzu tcases.
Re: Donor for SAS
[Re: RobG]
#336184
10/24/03 06:55 AM
ok first off i've never done one...duh....but............ i'd love to see someone do a coil sprung sas but like rob said, if u think about it, the leafs are much more forgivin in allowin you to not have to worry so much about extra links, if u get those links wrong on a coil....it's gonna suck! coils could pop out, it's gonna be wicked bad! but hey man, if you're good in math and wanna do some h/w go for the gold!!! get something that will flex like your rear set-up!
Re: Donor for SAS
[Re: RobG]
#336185
10/24/03 01:12 PM
I do know there is alot to learn but the reason I asked now without the knowlege is because I was at the junk yard and they had a waggy sitting there!I remember people say waggy axles and the thought crossed my mind,.........is there room in the garage? What could it hurt.....if I chose not to use it someone here could!!
'93 Trooper Ls
Re: Donor for SAS
[Re: mike_dup1]
#336186
10/24/03 07:52 PM
I've been playing with the idea of doing a sas on my trooper for awhile and the best axle of choice i have found for the second gen. troopers is an FJ80 toyota landcrusier axle. (92-97ish) they are basicly a bigger version of the mini truck axle. they are 63.5wide, high pinion with tie rod on the back side of the axle, bigger birfields, strong as hell, already comes with bigger brakes, third member style, avalible with an elocker, ect. they are a little pricey, but i believe well worth it. check out Housters web page on is swap , sorry i can't find the link, just do a search for FJ80. Eric
Re: Donor for SAS
[Re: Eric Upchurch]
#336187
10/25/03 01:31 AM
Dan's site is: www.houlster.comDana 44s and 79-85 Toy mini-truck axles seem like the most popular swap axles. The Land Cruiser FJ80 axle is stronger than both, and a Dana 60 is even stronger, still. That covers 95% of the swaps out there, but there are other more exotic swap possibilities like Unimog or Volve portal axles... The only limit to the possibilities is your imagination, skills, and funding. With enough time, cash, and skills, truely ANYTHING is possible. Randii
Re: Donor for SAS
[Re: randii]
#336188
10/25/03 01:49 AM
The only limit to the possibilities is your imagination, skills, and funding. With enough time, cash, and skills, truely ANYTHING is possible. OH WELL.......I'll stick to boating!! <img src="/forums/images/graemlins/shiner.gif" alt="" />
'93 Trooper Ls
Re: Donor for SAS
[Re: mike_dup1]
#336189
10/25/03 06:04 AM
Randi... I like the Vulva portal axles... haven't tried the volve....hehe... <img src="/forums/images/graemlins/evil.gif" alt="" />
