Placing the leaf springs over the axle will certainly give your rig excellent clearance and enhance it's present capabilities; but the reality is that it opens a Pandora's Box of modification issues and expenses. The modifications required should be only done by an experienced mechanic that has sucessfully modified other jeeps with a Spring Over Axle setups. We often read of problems where even the mechanically-inclined jeepers attempt the SOA and have significant never-ending problems. The simplest and possibly the stoutest solution, would be to keep the rig sprung-under with a 4" suspension lift kit (complete lift kit) and run 33" tires. I suspect that 33" tires will provide the necessary clearance on 75-95% of the trails you'll run. When you install taller ring & pinion gears to off-set the lack of vehicle highway performance from taller tires, go-ahead and install a full-locker in the rear differential, and a selectable locker in the front differential . . . this will make off-roading much more enjoyable. Rancho and Rubicon Edition lift kits are highly recommended, but there are others that are equal, and many that are worse for different reason. One thing should be obvious, don't purchase aftermarket kits or parts based on price, purchase proven systems and parts, some times your life may depend on the modifications you purchase. You can always post your plans here and gets some sound recommendations; this board has many experienced jeepers and mechanics who will gladly offer their experience and advice. See you on the trail . . .
