need p/n for longer studs for All-Pro 3/4" spacers #338825 10/29/03 01:55 AM
AlaskaToy Offline OP
Went to get a free balance since I swapped rims recently. the monkeys with the impact wrench cross-threaded and snapped a stud. Since it's non-stock, they didn't know what to order as a replacement. I do know it's a 1/2" stud.
I searched for dorman and stud and spacer, but couln'd find the dorman p/n for the studs AP uses with the 3/4" spacer. I need the number for the stud and the lug nut. Thanks.
AJ
93 Toyota, dana 60, 14-bolt
Re: need p/n for longer studs for All-Pro 3/4" spacers [Re: AlaskaToy] #338826 10/29/03 02:14 AM
anthony1 Offline
ok, I called Allpro for ya.
Aparently there are two part no. depend on what yr your axle is. the 79-81 has 6 holes rotors and after that it's 8 holes.
dorman part no.
early style 6 holes rotors... p/n 610-073
8 hole style...610-144
nuts
1/2x 20
I hope that helps.
Need anymore info just chime in.
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
Re: need p/n for longer studs for All-Pro 3/4" spacers [Re: anthony1] #338827 10/29/03 02:18 AM
Well. damn! <img src="/forums/images/graemlins/cheers.gif" alt="" /> Beers to you. Thanks! I can't believe how elusive that info has been. Thank you very much. <img src="/forums/images/graemlins/kewl.gif" alt="" />
AJ
PHP: 7.4.33 Page Time: 3.091s Queries: 15 (0.008s) Memory: 0.5938 MB (Peak: 0.6476 MB) Data Comp: Off Server Time: 2026-11-17 06:17:51 UTC
