Page 4 of 5 1 2 3 4 5
Re: 3.0L to 3.4L engine swap Q's #340598 11/03/03 12:01 AM
Yeah. The corner closest to the pulley. It's not a big deal at all, I can push the scoop about 1/2" to make it contact the blower, that's about how much the motor flexs under full bore acceleration. How can I post a pic? Does anyone know an easy way? (I don't want to register for one of those f%$^in sites that installs spyware either)
Re: 3.0L to 3.4L engine swap Q's #340599 11/03/03 12:03 AM
914Runner Offline OP
so i guess the best place to geta good wiring diagram would be from the dealer right? if i went there would they give one to me for free? <img src="/forums/images/graemlins/smile.gif" alt="" />
Thanks
1991 Toyota 4Runner 4 Door, 3.4l 5VZ-FE Engine Swap, R150F 5-Speed Manual, 4WD, 4.10's
My Rig
Re: 3.0L to 3.4L engine swap Q's [Re: 914Runner] #340600 11/03/03 12:19 AM
No. You're gonna need one like a fat kid needs cake though. I would call and get 2 EWD's tomorrow- one for your truck and one for the donor. If you don't know the donor year yet at least get the one for your truck and familiarize yourself with it. Get a DMM (digital multimeter) and map out all the connections to your body wiring to ECU harness. This will give you a big headstart, save downtime and let you know whether you're ready to take this on or have someone else do it smile
Re: 3.0L to 3.4L engine swap Q's #340601 11/03/03 12:26 AM
Don't bother the dealer for diagrams, as I stated earlier, call the Toyota Material Distribution Center
(800) 622-2033
Get the 91 4Runner EWD.
Re: 3.0L to 3.4L engine swap Q's #340602 11/03/03 12:40 AM
(800) 622-2033
i got all my books and diagrams from toyota dealership. they had it in acouple days for me.
Re: 3.0L to 3.4L engine swap Q's #340603 11/03/03 12:44 AM
I used to work for Toyota, that's where they'll get it from.
Re: 3.0L to 3.4L engine swap Q's #340604 11/03/03 01:18 AM
how much is this gonna cost me? what do you mean by map out all the body connections to ecu?
Thanks!
My Rig
Re: 3.0L to 3.4L engine swap Q's [Re: 914Runner] #340605 11/03/03 01:22 AM
Thanks!
i believe the wrie diagram books are about $30 a piece.
mapping out, meaning it shows/tells you in the diamgram e.g. tail light wire is this color on this harness plug, etc...
Re: 3.0L to 3.4L engine swap Q's #340606 11/03/03 01:39 AM
By map out I mean identify and verify all the wires you will be attaching to the 5VZFE harness. You'll need to find them and draw a diagram of what you have on your truck and place them on one side of your diagram that you'll make. The other side of your diagram will contain a list of all the 5VZFE harness wires connecting the engine/ECU to the body wiring. At this point you can begin scratching off all the wires that you have identified and reduce the nuber of unidentified wires that you'll encounter. You'll find wiring in the 5VZFE harness for a few items you won't need. Again, this is a tedious process even for someone who enjoys this sh*&. It took me a few hours just to identify all the wiring and label it, then a couple more hours to solder and shrink and loom the wiring to where it looks like it came from the factory.
As far as cost, it depends on what you're starting with- You need a DMM, heat gun, solder, soldering iron, EWD's, all tools to do swap, welder if you're doing your own exhaust, cutoff wheel for your hood, a place to do this, an understanding spouse if applicable, a friend to hold the other end of whatever while you try to..., about $1000 on hand in addition to the motor for headers, 2.5 inch cat, muffler, plumbing, electrical tape, bolts, tools you'll need along the way, beer, pizza, dope, whatever.
This is not a weekend project nor is it a good learning project for a beginner unless you've got plenty of time and another vehicle to drive. Between the wiring and the exhaust, you could eat up several weekends easily. It took me several months to do this because my wife doesn't share my love for things mechanical and won't tolerate more than one day a weekend.
Re: 3.0L to 3.4L engine swap Q's #340607 11/03/03 02:59 AM
ok i understand what you mean by map out. My son does races RC cars and he solders and stuff so i have a soldering iron, heat gun ect. I have access to just about any tool i think i will need. so it sounds good thanks for all of your guys help! i will ask any more questions i think of
Thanks for the help!
My Rig
Moderated by  4Crawler, 4x4Wire, Dandeman, kewlynx
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6264 MB (Peak: 0.7306 MB) Data Comp: Off Server Time: 2026-11-02 14:15:54 UTC
