Page 3 of 4 1 2 3 4
Re: engine choice #342392 11/20/03 06:02 AM
914Runner Offline OP
also since my rig has rear abs would i need to get a motor from a abs rig or not? toyota says theres a wiring harness for both abs and non abs?
Thanks!
1991 Toyota 4Runner 4 Door, 3.4l 5VZ-FE Engine Swap, R150F 5-Speed Manual, 4WD, 4.10's
My Rig
Re: engine choice [Re: 914Runner] #342393 11/20/03 06:14 AM
also whats the drive by wire thing? i thought all of the motors had a throttle cable instead of a electronic system?
Thanks
My Rig
Re: engine choice [Re: 914Runner] #342394 11/26/03 06:11 AM
well i got the motor today! its a 99 from a taco! what do i do anout the dipstick tube hole witht the plug in to can i unscrew it or pull it out or what?
Thanks for the help!!!
My Rig
Re: engine choice [Re: 914Runner] #342395 11/26/03 08:25 AM
kewlynx Offline
If like my 22R, should pull out with a little effort. Might need to PB Blaster it first.
I will say this; make note of the length of the tube/stick. Even with a 22R out of a 2wd (Celica) and my 4wd dipstick tubes differed about an inch or so in length. <img src="/forums/images/graemlins/wink.gif" alt="" />
**ubi apis- ibi salus**
Re: engine choice [Re: 914Runner] #342396 11/26/03 09:07 PM
you will need to drill it out. the dip stick should just fit in. the o-ring seals it. the unused hole will have to be plugged up, either tapped and bolted closed, or plugged up with a metal plug.
Re: engine choice #342397 11/27/03 04:37 AM
ok thanks i hope to get this part done tonight!
My Rig
Re: engine choice [Re: 914Runner] #342398 11/30/03 03:25 AM
well i started to look at my motor a bit and i found water in cyclinder #3 but none others. i got it out and got the motor to turn over by hand. what might have caused this? the motor sat for 2 years at the wrecking yard before i bought it. it has 30,000 on it!
My Rig
Re: engine choice [Re: 914Runner] #342399 11/30/03 06:22 AM
how much water?
was there any water in the oil or was the old already drained when you got the engine?
when I got my engine, it was came from a 4runner that was recently wrecked and just arrived to the salvage yard. it had 36k miles on it.
I did find alittle cream color liquid in the bottom of the pan after I drained the oil, I believe it came from condensation from sitting at the auction place for so long.
Re: engine choice [Re: 914Runner] #342400 11/30/03 07:32 PM
bwhitehead Offline
Why the need for the changing the dip stick?
93 4Runner 3.4 swap, SAS, 37 Mtr, 5speed swap, High pinion ARB Front an Arb rear, ARB air compressor, Marlins Dual cases, bud built crossmemeber, 63 leaf spring swap. Sky rear disc conversion and the money keeps flowing!
Re: engine choice [Re: bwhitehead] #342401 11/30/03 07:42 PM
well i am told i need to move it back so it oesnt get in the way but i have never been told of what it getts in the way of so i might just try to leave it where its at.
My Rig
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.007s) Memory: 0.6402 MB (Peak: 0.7598 MB) Data Comp: Off Server Time: 2026-11-15 07:06:20 UTC
