Tire and rim opinions needed! #343636 11/07/03 07:29 PM
Little_Dog Offline OP
My original plan for 16" rims is not working out. My current tires are 215/75- 15 mudders <img src="/forums/images/graemlins/frown.gif" alt="" />. I will be installing 4.625 open diffs this weekend and a Roger Brown 1" body lift next weekend. I have three questions for the forum: 1.) will 33 x 12.50 15's be too much for my stock 2.6? 2.) will they fit on 8" rims? 3.) which is more practical for the trail, steel rock crawlers or cheap alloys?
70 FJ40 under construction
Re: Tire and rim opinions needed! [Re: Little_Dog] #343637 11/07/03 07:51 PM
Not if its running properly.
Yes
Steel can be bent back. Aluminum can't. You will bend either when crawling.
Re: Tire and rim opinions needed! [Re: Little_Dog] #343638 11/07/03 09:27 PM
I think I would do the body lift and axle install at the same time.
Re: Tire and rim opinions needed! [Re: off-roader] #343639 11/07/03 09:39 PM
LRJ4x4 Offline
33's will be ok for a farm truck / trail rig but forget about going uphill on the freeway with the 2.6
Les
Re: Tire and rim opinions needed! #343640 11/07/03 11:15 PM
Essentially, it will be done at the same time since I won't put new tires /rims on until both are completed. Since I posted this AM, I am once again considering 16" rims with 235/85 16 mudders. They are 32" by about 9.5. I like the idea of a 10 ply or 8 ply tire since I will still need to work this truck besides play on the trails. I'm still interested in more opinions... Thanks to all.
Re: Tire and rim opinions needed! [Re: Little_Dog] #343641 11/08/03 02:15 AM
PartyTruck Offline
Every time someone uses the words "going bigger" and "235/85 15" in the same sentance it allways makes me think of my friends Suzuki SJ410.
He understood the "going bigger" <img src="/forums/images/graemlins/kewl.gif" alt="" />
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
PHP: 7.4.33 Page Time: 0.010s Queries: 14 (0.007s) Memory: 0.6100 MB (Peak: 0.6797 MB) Data Comp: Off Server Time: 2026-11-18 05:15:27 UTC
