REPAIR MANUAL FOR NEWER ISUZU MODELS??? #343899 11/08/03 09:14 AM
Does Chilton make a book or any other manufacture, especially with details on troubleshooting and pictures showing details on doing work on them.
I'm having the some issues with my 2000 Isuzu Amigo V6 5spd. The check engine light comes off and on, usually after I get gas which led me to believe it was the gas cap, then it would come on later after it has gone off and does it off and on once in a while.
The other thing is the idle of the engine as when I come to a red light or when I put in into neutral it sometimes dies or the gauge will go up and down slowly between the 0 and 1. It does this sometimes, not all the time though, it is just real annoying. Any ideas?? I have crossposted this so that some that would not see it would be able to read it.
Re: REPAIR MANUAL FOR NEWER ISUZU MODELS??? #343900 11/08/03 12:05 PM
The best service manual for isuzu can be found here: Helms
A new gas cap will probably solve your CEL problem. You are likely getting evap. system codes due to a leaky check valve in the gas cap. $2 fix!!
G/luck
Joel
Re: REPAIR MANUAL FOR NEWER ISUZU MODELS??? #343901 11/08/03 02:47 PM
rubo Offline
You might wanna change the fuel filter. It ussualy is causing the problems you described (stalling when comming to a stop, uneven idle). It's a shot in the dark without seeing what it realy does, but filter are relatively cheap & easy to replace.
rubo
"If i can't crawl over it, i'll fly over it"
rubo
'96 Amigo 4x4, 3.2L V6, 4L30E, D44 rear, SOA, 1" BL, undergoing surgery.
'00 Rodeo LS 4x4, 3.2L V6, OME 919 Springs, front cranked to match,1" BL, 265/70x16 Scorion A/T's.
Re: REPAIR MANUAL FOR NEWER ISUZU MODELS??? #343902 11/09/03 09:44 AM
Haynes just put out an updated manual for 2nd generation Rodeos and Amigos. Here is a link to one on eBay, although I found one at Autozone as well and it will save you shipping charges. I also found a genuine shop manual on CD that covers Rodeos and Passports for about $12. It should also work for late model Amigos as they are almost the same internals. First link is Haynes, second is the factory shop manual.
http://cgi.ebay.com/ebaymotors/ws/e...p;category=43998&item=2441020394
http://cgi.ebay.com/ebaymotors/ws/e...p;category=34223&item=2441887937
The Haynes manual has mostly pics for older models as it is basically an older model repair manual with addendums for the newer Rodeos and Amigos. My vote would be for the genuine factory manual. I ordered one, but haven't got it yet. Feel free to email me in a week or so and I can describe it in detail for you if you want. Good luck.
RB
Re: REPAIR MANUAL FOR NEWER ISUZU MODELS??? #343903 10/01/11 02:29 AM
samsith Offline
try to check out automd, they have this [color:"black"]Isuzu repair[/color] tips and techniques. they have auto repair manuals for all the car.
PHP: 7.4.33 Page Time: 0.016s Queries: 14 (0.012s) Memory: 0.5979 MB (Peak: 0.6619 MB) Data Comp: Off Server Time: 2026-11-16 08:50:00 UTC
