Serious Shifting Problems - Clutch Cable??? #345440 11/11/03 02:18 PM
Sherpa Offline OP
I took Sherpa out for a drive yesterday for the first time in over a week. Well, I had a terrible time trying to get it into gear. For the last few weeks I have heard a consistent squeak each time I actuated the clutch. It feels like my clutch cable is sticking. Is there any way to lubricate it?
1997 SR5 5-Spd. TRD Supercharger, URD Supercharger Performance Kit, "Bamachem Designed" 2.5" suspension lift, 265/75R16 Bridgestone Dueller Revos, Airbox Mod, Amsoil: (Air Filter plus engine, diff, x-fer case, + tranny oils)
Re: Serious Shiting Problems - Clutch Cable??? [Re: Sherpa] #345441 11/11/03 03:31 PM
FattyCBR Offline
There is a rubber bushing at the top of the clutch pedal where it pivots that goes bad frequently and that sounds like your problem. I believe there is a write-up on fixing it either on here or yotatech.
BTW, nice typo in the title. "Serious Shiting Problems." <img src="/forums/images/graemlins/lol.gif" alt="" />
Milan
_ _ _ _ _ _ __ _ _ _ _ _ _
Support our troops!
'98 4R Limited
'82 Toy 4.3 TBI sold
Re: Serious Shiting Problems - Clutch Cable??? [Re: Sherpa] #345442 11/11/03 04:14 PM
James Chow Offline
I had noises on two occasions. Once, there was a "click" when the pedal was nearly all the way depressed. Clutch master was leaking. Next time (more recently), there was a slight squeak when depressing the pedal. I flushed w/ new Valvoline dot 4 synthetic brake fluid and all has been well since. The clutch fluid turns brown much sooner than brake fluid. I think the turning brown is heat-induced. Once it turns brown/tan, I change it.
'86 4Runner: ARB winchbar, Kaymar, e-codes, OME lift, RR diff lock, FR truetrac, sound stream a/d/s audio, recaros.
'03 LX470: ARB sahara bar, Kaymar, HID's, ART cryo'd/slotted rotors, Stoptech SS hoses.
'01 Prelude SH
'00 CRV
Re: Serious Shiting Problems - Clutch Cable??? [Re: FattyCBR] #345443 11/11/03 05:08 PM
This was my problem. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: Serious Shiting Problems - Clutch Cable??? #345444 11/11/03 06:07 PM
Dude,
I'm sorry to hear about your Serious Shiting Problems. You should go to the Doc if it's real bad.
dont eat salsa. it'll burn.
<img src="/forums/images/graemlins/smile.gif" alt="" />
mike
Re: Serious Shiting Problems - Clutch Cable??? [Re: Sherpa] #345445 11/11/03 10:18 PM
What up Sherpa.
Had the same noise. I had my clutch assembly at the fire wall replaced under warrenty.
Re: Serious Shifting Problems - Clutch Cable??? #345446 11/11/03 11:51 PM
Sherpa Offline OP
Uhh... Oops! Haa haa haa! For someone who really works to not make many grammatical errors, that was a pretty good one! <img src="/forums/images/graemlins/shocked.gif" alt="" />
Thanks for all your support on my serious, and personal problem. I will change my diet and reduce my dependency on salsa. Hopefully this will all pass! (I just couldn't resist the pun!)
-S
Re: Serious Shiting Problems - Clutch Cable??? #345447 11/11/03 11:54 PM
Sherpa Offline OP
What up Sherpa.
I am a long way past my warranty. I hope this isn't too expensive. I need to get Sherpa running well for a road trip over Thanksgiving!
Please keep the suggestions comming. (ie: How much $ will this run to repair/replace?)
-S
Re: Serious Shifting Problems - Clutch Cable??? [Re: Sherpa] #345448 11/11/03 11:57 PM
Sherpa Offline OP
I have learned that Toyota trucks do not use cables, but are hydraulic. Where are the linkages, and would lithium grease be a good thing to use?
-S
Re: Serious Shiting Problems - Clutch Cable??? [Re: James Chow] #345449 11/12/03 02:02 AM
... Once, there was a "click" when the pedal was nearly all the way depressed. Clutch master was leaking. ...
so was this 'click' you speak of related to the clutch master leaking. i noticed that my clutch started 'clicking' last week. there's a little bit of oil on the driver's kick plate. but i couldn't locate the location of the click, so i just attributed it to the clutch return spring. so i'm assuming that my master cylinder is leaking. where is it located so i can refill it. and it the clicking because it's low on fluid or is something broken? it's an old truck and i'm not ready to put a bunch of money in it to replace the master cylinder. i'd be really happy if i can just get away with refilling it.
thanks!
mike
PHP: 7.4.33 Page Time: 4.773s Queries: 16 (0.005s) Memory: 0.6311 MB (Peak: 0.7537 MB) Data Comp: Off Server Time: 2026-06-22 17:06:05 UTC
