Serious Shifting Problems - Clutch Cable???
#345440
11/11/03 02:18 PM
I took Sherpa out for a drive yesterday for the first time in over a week. Well, I had a terrible time trying to get it into gear. For the last few weeks I have heard a consistent squeak each time I actuated the clutch. It feels like my clutch cable is sticking. Is there any way to lubricate it?
1997 SR5 5-Spd. TRD Supercharger, URD Supercharger Performance Kit, "Bamachem Designed" 2.5" suspension lift, 265/75R16 Bridgestone Dueller Revos, Airbox Mod, Amsoil: (Air Filter plus engine, diff, x-fer case, + tranny oils)
Re: Serious Shiting Problems - Clutch Cable???
[Re: Sherpa]
#345441
11/11/03 03:31 PM
There is a rubber bushing at the top of the clutch pedal where it pivots that goes bad frequently and that sounds like your problem. I believe there is a write-up on fixing it either on here or yotatech.
BTW, nice typo in the title. "Serious Shiting Problems." <img src="/forums/images/graemlins/lol.gif" alt="" />
Milan _ _ _ _ _ _ __ _ _ _ _ _ _ Support our troops!
'98 4R Limited '82 Toy 4.3 TBI sold
[Re: Sherpa]
#345442
11/11/03 04:14 PM
I had noises on two occasions. Once, there was a "click" when the pedal was nearly all the way depressed. Clutch master was leaking. Next time (more recently), there was a slight squeak when depressing the pedal. I flushed w/ new Valvoline dot 4 synthetic brake fluid and all has been well since. The clutch fluid turns brown much sooner than brake fluid. I think the turning brown is heat-induced. Once it turns brown/tan, I change it.
'86 4Runner: ARB winchbar, Kaymar, e-codes, OME lift, RR diff lock, FR truetrac, sound stream a/d/s audio, recaros. '03 LX470: ARB sahara bar, Kaymar, HID's, ART cryo'd/slotted rotors, Stoptech SS hoses. '01 Prelude SH '00 CRV
[Re: FattyCBR]
#345443
11/11/03 05:08 PM
BTW, nice typo in the title. "Serious Shiting Problems." <img src="/forums/images/graemlins/lol.gif" alt="" /> This was my problem. <img src="/forums/images/graemlins/shiner.gif" alt="" />
#345444
11/11/03 06:07 PM
Dude,
I'm sorry to hear about your Serious Shiting Problems. You should go to the Doc if it's real bad.
dont eat salsa. it'll burn.
<img src="/forums/images/graemlins/smile.gif" alt="" />
mike
[Re: Sherpa]
#345445
11/11/03 10:18 PM
What up Sherpa.
Had the same noise. I had my clutch assembly at the fire wall replaced under warrenty.
Re: Serious Shifting Problems - Clutch Cable???
#345446
11/11/03 11:51 PM
Uhh... Oops! Haa haa haa! For someone who really works to not make many grammatical errors, that was a pretty good one! <img src="/forums/images/graemlins/shocked.gif" alt="" />
Thanks for all your support on my serious, and personal problem. I will change my diet and reduce my dependency on salsa. Hopefully this will all pass! (I just couldn't resist the pun!)
-S
#345447
11/11/03 11:54 PM
What up Sherpa.
Had the same noise. I had my clutch assembly at the fire wall replaced under warrenty. I am a long way past my warranty. I hope this isn't too expensive. I need to get Sherpa running well for a road trip over Thanksgiving! Please keep the suggestions comming. (ie: How much $ will this run to repair/replace?) -S
[Re: Sherpa]
#345448
11/11/03 11:57 PM
I have learned that Toyota trucks do not use cables, but are hydraulic. Where are the linkages, and would lithium grease be a good thing to use?
-S
[Re: James Chow]
#345449
11/12/03 02:02 AM
... Once, there was a "click" when the pedal was nearly all the way depressed. Clutch master was leaking. ... so was this 'click' you speak of related to the clutch master leaking. i noticed that my clutch started 'clicking' last week. there's a little bit of oil on the driver's kick plate. but i couldn't locate the location of the click, so i just attributed it to the clutch return spring. so i'm assuming that my master cylinder is leaking. where is it located so i can refill it. and it the clicking because it's low on fluid or is something broken? it's an old truck and i'm not ready to put a bunch of money in it to replace the master cylinder. i'd be really happy if i can just get away with refilling it. thanks! mike
