Page 3 of 3 1 2 3
Re: According to dealership my Bosch 4 plugs are the reason for my check engine light on and misfiri [Re: DaphneD] #346677 02/07/04 03:08 PM
Dandeman Offline
Toyota Moderator
Ditto on the electrical engineering lesson: Electricity will follow the path of least resistance. Translated to Bosch 4-prongs that means that the electricity is going to choose one prong and stick with it (probably the closest in proximity with the least resistance).
I have read that the NGK twin electrode plugs are laser trimmed to get the gaps to each electrode exactly equal.. If you pump enough energy into it, it will flash across both electrodes..
Actually electricity flow divides across multiple paths with current flow in inverse proportion to the resistance of each path..
Re: According to dealership my Bosch 4 plugs are the reason for my check engine light on and misfiring [Re: TooEZgoin] #346678 02/11/04 05:31 PM
Actually something similar happened to me with the SplitFire plus on my '94 3.0. After blowing the head gasket, factory recall, the tech actually told me something interesting. He suggested to only run "stock" plugs on any Toyota motor. The "extra spark" generated by SplitFire, etc. type plugs gets relayed to the ECU & knock sensor as detonation and hence changes the timing, in essence, changing the fuel mixture. He said he's seen many motors damaged or running poorly due to the plug change...that and different plug wires. And I have to agree. When I did all the mods to my '88 Runner 3.0, I originally had Bosche plus in it, along with MSD wires...I kept getting ECU codes, etc...put fatory plugs and wires in, problem solved.
So good luck with it.
Greg
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.5909 MB (Peak: 0.6575 MB) Data Comp: Off Server Time: 2026-06-22 20:21:22 UTC
