Help! Front truck axle won't go back in! PART TWO. #348780 11/17/03 01:22 PM
Little_Dog Offline OP
The sad/ funny part of this is that its NOT THE DRIVER'S SIDE axle. It went back fine. It's the pass side that just bolts to the flange. The axle, still attached to the unmolested Superwinch hub, is about an inch too long and I can't coax it back to permit the spindle to attach to the upper ball joint. My first thought is that it disengaged from the hub while I did the axle removal. Has this happened to anyone else?
70 FJ40 under construction
Re: Help! Front truck axle won't go back in! [Re: Little_Dog] #348781 11/17/03 01:44 PM
MontyGrant Offline
i'd say just keep trying. spin it while you do it. have someone help support. i ran into a similar problem helping a friend put his axles back together on a D-90. we ended up using 3 people to keep it steady while we slowly put it back and tried to get the splines to line up.
-Grant
'98 Montero with 135k miles
Re: Help! Front truck axle won't go back in! [Re: Little_Dog] #348782 11/17/03 04:10 PM
NathanC Offline
Pull the Superwinch hub and make sure that the clip didn't come off. I'd bet that's the problem.
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: Help! Front truck axle won't go back in! [Re: NathanC] #348783 11/18/03 12:20 AM
The clip has come off the other side numerous times. I used my grinder to deepen the groove for the snap ring on that axle yesterday when I had it out. I bought a slightly smaller snap ring as well. I think your idea is good, Nathan. Unfortunately, electrolysis has set in and those pesky allen head bolts on the hubs won't budge for love or money. <img src="/forums/images/graemlins/angry.gif" alt="" />
Re: Help! Front truck axle won't go back in! [Re: Little_Dog] #348784 11/18/03 12:26 AM
NathanC Offline
Get a punch that just fits inside the head, and smack it with a BFH <img src="/forums/images/graemlins/smile.gif" alt="" />. That works most of the time. I know what you are talking about though, anti-seize has become my best freind <img src="/forums/images/graemlins/wink.gif" alt="" />.
'88 Mighty Max
Re: Help! Front truck axle won't go back in! [Re: NathanC] #348785 11/18/03 12:43 PM
X L N T! I have PLP (puny little punch) and a BFH. <img src="/forums/images/graemlins/smile.gif" alt="" /> It looks like T-giving weekend for next time to work on it. Another soccer tournament for number one son next weekend.
Re: Help! Front truck axle won't go back in! PART TWO. [Re: Little_Dog] #348786 11/24/03 01:08 PM
Well, I got to this Saturday. The snap ring was in place and unmolested. I got the hub screws off with a Torx- 20 bit except for one that required a screw extractor. It now looks like its the inner CV joint that has become hyperextended. I was able to pull the axle out with the spindle and hub attached to the A arms. At least it's drivable now.
PHP: 7.4.33 Page Time: 2.705s Queries: 15 (0.016s) Memory: 0.6172 MB (Peak: 0.6916 MB) Data Comp: Off Server Time: 2026-11-18 05:15:54 UTC
