voltage problem #351006 11/21/03 03:07 PM
doc long Offline OP
about six months ago this started.
when i start the jeep the voltage is about 12. if i rev the engine, the voltage jumps up and stays at 14. i tightened the belt and it isn't squeeling. i replaced the alternator with another basic 63 amp, and it still does it.
any ideas
thanks
Brian
Re: voltage problem [Re: doc long] #351007 11/21/03 04:36 PM
Mike Bondi Offline
Brian...What you are describing is fairly normal. A 12 volt battery charges at around 13.5 volts, and once the surface charge wears off, it settles down to a little over 12 volts. My 90 Wrangler charges at 14 volts, and when I start the critter in the morning, the battery is sitting close to 12. A defective battery will often show a high voltage in the 15 to 16 volt range, but from what you are saying, things don't sound too far from normal. Your voltage regulator may be sticking a little, if you need to rev the engine for charging to take place...Be cool...Mike <img src="/forums/images/graemlins/oink.gif" alt="" />
2013 Wrangler Rubicon, 2014 Jeep Cherokee Latitude, 09 Mercedes Benz ML350 4matic...Old scooter trash trying to do good, in the flat lands of Indiana
Re: voltage problem [Re: doc long] #351008 11/21/03 06:27 PM
If you are running a 1 wire altrnator , havinf to rev it is normal to get the charging voltage up. are you running an internal or external regulator? if it is external check your grounds.
Re: voltage problem #351009 11/21/03 07:25 PM
doc long Offline OP
it's an internal voltage regulator. standard wiring setup.
maybe i just need to check the contacts. the wierd part is that it was doing it before and after the new alternator and the new alt has a new regulator in it.
any other ideas might help. i'm gonna go through all the contacts this weekend and see if it helps.
thanks guys.
Brian <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: voltage problem [Re: doc long] #351010 11/22/03 02:59 AM
do you have a resistor in your field exhitaion lead? what year jeep is this in?
Re: voltage problem #351011 11/22/03 03:38 PM
doc long Offline OP
83 cj7,258, not sure about the resistor
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.010s) Memory: 0.6050 MB (Peak: 0.6705 MB) Data Comp: Off Server Time: 2026-11-18 03:35:36 UTC
