Coolant in Oilpan!! Help. #35133 06/06/02 03:18 AM
G
Genshie Offline OP
Just bought an 85 4runner 22RE Auto with 200K for a song. Outstanding condition except the timing chain is broken. I am in the process of putting in a new one and discovered when draining the oilpan that a LOT of coolant came out before the oil did. I am thinking it could be one of three things:
1 When timing chain broke, it put a hole in the water jacket and leaked into the motor.
2 Head gasket is blown.
3 The motor needs a ring job.
Hopefully the answer is #2!
When I bought it the previous owner said that it did not leak or burn any oil before the timing chain broke and that it passed smog with no problems at all. The truck is in overall great condition, so I am thinking it wasn't abused too badly during its life.
What are some of the other possibilities with this? It has a new radiator and water pump. I am pulling the head tomorrow to take a look at the cylinders.
Any advice or expertise would be most appreciated!
Kurt G.
Dented 85 4Runner courtesy of Wrecking Ball.
Re: Coolant in Oilpan!! Help. #35134 06/06/02 03:50 AM
Noooo, hopefully the answer is #1 <img border="0" title="" alt="[Smile]" src="images/icons/smile.gif" />
It is very likely that if the timing chain broke, it was due to slack in the tensioner and guides. This would lead to wear in the timing chain cover which has a coolant passage in it.
Pull the timing cover and take a look at the back side of it. I'll bet you'll find that it has a hole torn through it.
Re: Coolant in Oilpan!! Help. #35135 06/06/02 05:41 AM
G
Genshie Offline OP
Jim,
Thank you. I was hoping that you would reply to my message! I am pulling the cover tomorrow and we will see what hides behind there. Thanks again for the info.
Kurt
PHP: 7.4.33 Page Time: 1.544s Queries: 14 (0.005s) Memory: 0.5903 MB (Peak: 0.6438 MB) Data Comp: Off Server Time: 2026-11-15 17:52:22 UTC
