HEI #353050 11/25/03 04:32 AM
Looking at an HEI conversion. Which one is good? What have you guys used? Have read many articles and most of them came out of a junk yard not very many left if any that I have seen. Is there a bolt in one you can get or one that does not need a bunch of work to get it right? Any info is great info.
Thanks, Scott <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: HEI #353051 11/25/03 05:50 AM
mwhite Offline
This should tell you what you need to know.
http://www.4x4wire.com/jeep/tech/electrical/hei02/
88 Mighty Max 2.6 (170,000miles)
3 body lift, 1 1/2 torsion lift, lower bumpstops, 4.625
gears, 31 1/2 buckshot radials,warn 8274
Re: HEI [Re: mwhite] #353052 11/25/03 06:22 AM
Thanks Mike have read that before. But is there a HEI out there that is aftermarket that will work? Like I said there are not a lot of those around here in the wrecking yards. I am not a chevy guy so not sure what to look for in a HEI. The only chevy I owned was pionts and that got changed to a MSD.
Re: HEI #353053 11/25/03 07:00 AM
There is an aftermarket distributor from Davis Unified Ignition. Be prepared to spend about $360. I would definitely just go to the pick-n-pull and get a core. (And if you're lucky a drive gear as well) Then go get some new parts for it. That will be the easiest road to take. In my area, getting the core was the hardest part, but cost and performance-wise it was well worth the effort.
Re: HEI #353054 11/25/03 07:09 PM
jeepfun4u2 Offline
i am using a davis on my rig. no problems, a great unit! but i'm comparing it to the prestalite (eeek) that i had before. what i like about it is that you can use gm parts when something breaks, and i'm in a sort out-of-the-way place in mexico. gm parts are easy to get here. anyway, thumbs up on the dui ignition! good luck, rob
American in Mexico with my 76 CJ7,4.6 Liter I6
Weber 32/36,Header,FlowMaster,DUI Ignition
3"Lift,33's,TH400 Tranny/Dana 20
Re: HEI [Re: jeepfun4u2] #353055 11/25/03 08:40 PM
I just upgraded my 83 CJ7 with a 258 this past weekend, with the HEI dist.. Works GREAT!! I got my rebuilt unit with a warranty from Cape Connections @ www.driveajeep.com $209.00. Just dropped it in an go. I have Howell TBI, and i just disconnected the TFI and a MSD 6 box off my jeep.
Re: HEI #353056 11/26/03 03:50 AM
Thanks for the info guys will look at the options. Just got my header so am working on that at the moment. HEI will have to wait till next weekend.
Re: HEI #353057 11/26/03 04:15 AM
I just installed this kit on my cj. I have not tried it yet, but the install was easy and the kit only cost $109. http://driveajeep.com/
Re: HEI #353058 11/26/03 06:53 PM
DrDon,
You must have gone with the TFI upgrade vs the HEI Distributor. ??
Re: HEI #353059 12/03/03 07:47 PM
doc long Offline
hey Roger,
i have the tfi right now with the howell.
do you like the hei better? is it worth it?
i'm pretty happy with the tfi. what made you switch?
Brian <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6179 MB (Peak: 0.7217 MB) Data Comp: Off Server Time: 2026-11-16 03:02:28 UTC
