Rear Leaf Spring #355650 12/01/03 02:07 AM
Broke a left rear leaf on a 1997 tacoma 4x4. Will a set off a 2002 tacoma work under this truck? Thanks, Scott. --------------------------------------------------------- 1997 t-100 sr5,rs5000,31" buckshots
Re: Rear Leaf Spring #355651 12/01/03 03:35 AM
E
EQuin Offline
I believe the 95.5 to 97 Tacomas used shorter leaf packs and that the 98 and newer Tacoma leaf packs won't fit. Could be wrong about that, though. I also remember reading a few posts on tacomaterritory.com that the 95 and older, non-Tacoma 4x4 leaf packs are a perfect fit for the 95.5 to 97 Tacoma 4x4s, but I don't know if they provide lift or retain the stock ride height.
Hope this helps.
Ed Q.
03 TRD Tacoma Ext Cab 3.4L 4x4
93 Ford Bronco
86 Ford Bronco
47 CJ2A Willys
Re: Rear Leaf Spring [Re: EQuin] #355652 12/03/03 03:20 AM
the 95.5 - 97 tacos are very bad for breaking the center leaf on the rear
you can either spend the bux on the stock springs or get a lift <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Rear Leaf Spring #355653 12/04/03 10:24 PM
Later Taco spring will not work without a new front hanger. However, 90-95 truck spring will work. They will also give you about 1.5" of lift, so the front would definately need some lift as well.
Re: Rear Leaf Spring #355654 12/04/03 10:40 PM
I broke a leaf in my 87 toy, what a PIA to replace those suckers.
It may not be worth using poly. bushings. I stayed with the rubber ones.
good luck
Re: Rear Leaf Spring #355655 12/07/03 09:36 PM
rrolsbe Offline
I read in this forum that the 1996 non TRD 4X4 Tacoma pickups had fewer leafs than the newer TRD Tacoma pickups. I checked out a TRD Tacoma pickup in the parking lot and it appeared to have the same number and thickness leafs, not sure about the length. I bought my 1996 4X4 XCab used so I do not no its history. What does the X on the tailgate mean? Does it simply mean that it is an extended cab XCab? Bottom line is I do not know if I have the better leaf spring setup or not?
Later
Ron
1996 Toyota Tacoma XCab 4x4 3.4L
ARB Bullbar & Warn Winch
Super Spring progressive leaf springs
SuperBumper in rear 2" receiver
Moderator Marks factory Bilstein shocks/Front Coils
Albuquerque, NM
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5989 MB (Peak: 0.6661 MB) Data Comp: Off Server Time: 2026-06-21 01:40:21 UTC
