Thank's for the heads up peeps! Where should I look to order longer AALs. I saw the ProComp AALs on pepboys.com. By chance, if I do get the ProComp AAL and it raises the rear a little higher than the front what would you recommend me doing to level my 4runner if you say don't crank the T-bars?
It shouldn't raise the rear that high if it is sagging. I now have both a long rancho aal and the short procomp aal and my rear sits slightly higher than the front unladen. But when I throw all my camping and wheeling gear in the back it levels out.
Many people do crank their t-bars and swear by it. But then a lot of people complain about their IFS sucking because it won't flex. I'll bet there is a big overlap between those two populations.
A little bit is probably ok to get it leveled out, just remember to go get an alignment after you do it. But cranking them too much will only limit your flex offroad even more. This is not a result any added stiffness per se, it has to do with the geometry of the suspension. A greater angle between the control arms and the ground (away from parallel) reduces the force vector trying to twist the torsion bar.
If your rear end is sticking up way too high, you may want to try removing one of the stock leaves from your pack and see what happens. Also, the aal will settle down over time. You could always put the leaf back in if it settles down too much.
Oh yeah, I'd have some extra U-Bolts on hand... It seems like I blast the threads off of one or two of them every time I r&r my springs.
