what can cause a clutch to disintegrate?
#359149
12/07/03 03:31 AM
my clutch exlopded...i fished a few peices of my clutch plate out thru my throw arm boot on the bottem of the tranny. clutch was brand isuzu parts just 2 years ago. i am going to pull it apart nad fix it and probably sell it, but i am just wondering if it is p[ossible to put it in wrong...cause otherwise how else does it blow up after just 2 years....roughly mayyyyyybe 10000 miles. probably not even that many miles thouhg.
Joe Mancin 85 Toy ex-cab 33s
Re: what can cause a clutch to disintegrate?
[Re: TROOPOWER]
#359150
12/07/03 06:13 AM
If you install the clutch plate backwards on a Æ91, the spring pack on the clutch plate will not have enough clearance and the clutch will NOT disengage. There is not enough room in the flywheel cavity for the clutch plate spring pack (which is different from the pressure plate springs). If it worked properly, you must have put it together right.
If the clutch get burned or overheated several times, it can be weakened and can later disintegrate. Hope this is of help.
See you out there, Dave
91 Trooper. Mostly stock. Takes me where I want to go and brings me home when I'm done playing.
[Re: ChulaVistaDave]
#359151
12/07/03 07:42 AM
water on a hot clutch did mine.
#359152
12/07/03 03:18 PM
I scattered a race car clutch once when I missed third gear with the throttle nailed.
A while back Frisky did a clutch job at my house and his old flywheel had small hairline cracks in it. It was destined to let go at the most inopportune time. HE wisely replaced the flywheel even though it meant hitch hiking to work for a week whiole a replacement could be shipped.
With only 10,000 miles on it means it has had a hard life, or was defective to begin with. #2 is very rare.
Curtis J
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5962 MB (Peak: 0.6544 MB) Data Comp: Off Server Time: 2026-06-13 18:44:27 UTCValid HTML 5 and Valid CSS
