Automatic trans 89 4ez1
#360162
12/09/03 02:21 AM
Took my truck for its maiden voyage after I bought it.The tranny wont shift past third until it warms up.After about2 miles it will shift all the way to overdrive.I've been told this is normal.Is this true or do I have a problem?If so what do I look for? Thanks for any advice
Re: Automatic trans 89 4ez1
[Re: RSimister]
#360163
12/09/03 04:52 AM
That is exactly right. They do not shift in to overdrive until the temperature comes up. This is normal and nothing to worry about.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake 1989 Trooper 2.6 auto 1989 I-Mark RS DOHC 1.6 1991 Stylus XS DOHC 1.8
[Re: RSimister]
#360164
12/10/03 08:27 AM
don't worry about this normally the change of 3r to over drive if it does not have the temperature necessary to work not does it, I recommend you that verify if the thermostat it's coolant system because some times it is reason not to have the temperature that needs the transmission oil
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5874 MB (Peak: 0.6420 MB) Data Comp: Off Server Time: 2026-06-18 09:56:23 UTCValid HTML 5 and Valid CSS
