broke the wire comming from oil sending unit... #360650 12/09/03 07:12 PM
i wasa putting in a new fuel filter and cought the wire. how can i fix this? it snapped flush with the fitting. i'm not worried about it right now, cause i have the instr. cluster without a tach, so its just an oil light. in a few weeks i'll be putting in a cluster with a tach, replacing the sending unit, but i will still need this wire and fitting i broke.
any help would be much appreciated.
Re: broke the wire comming from oil sending unit... #360651 12/10/03 12:29 AM
b4wheeler Offline
Where did it break.? I know on my truck there is actually a short pigtail connected to the main harness. This pigtail can be picked up at the dealer for either the oil psi sender or the idiot light sender. I think they are less then $10.
92 Toy XtraCab,SAS, Dual Ultimate Marlin Crawler, 5.29s, ARB/front, Detroit/rear, Bobbed Bed, 36" IROKs, BudBuilt crossmember, Longfields, AP Chromo inners
Re: broke the wire comming from oil sending unit... [Re: b4wheeler] #360652 12/10/03 01:04 AM
it broke right behind the idiot light sender.
you saying that wire is can seperate from the harness?
Re: broke the wire comming from oil sending unit... #360653 12/10/03 01:19 AM
OOP'S Offline
Crimp a new wire end on!!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: broke the wire comming from oil sending unit... [Re: OOP'S] #360654 12/10/03 02:52 AM
it broke flush with the sender. there nothing to crimp to.
Re: broke the wire comming from oil sending unit... #360655 12/10/03 03:20 AM
5spd Offline
Solder it then, must me a piece of metal left on it....
Re: broke the wire comming from oil sending unit... [Re: 5spd] #360656 12/10/03 04:47 AM
nope, not a bit. must have been real brittle. think i will go to the dealer and see if they have just that piece like that other guy said.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6042 MB (Peak: 0.6804 MB) Data Comp: Off Server Time: 2026-06-17 07:41:26 UTC
