DIY headers?
#360947
12/10/03 02:31 AM
So I got to thinking (after watching a lot of Monster Garage episodes... so don't hold that against me) why not just make a custom set of headers for the 3.0? If downy and the other company suck so much, why not just bend up some pipe and be done with it? I know it is more complex than that, but basically don't you need a tube bender, welder, and the correct size/type of pipe?
Tom -|- TLCA #12384 -|- '95 4x4 x-cab mini Finally E-locked... 1987 Celica GTS liftback - stock for now ...never enough...
Re: DIY headers?
[Re: tkrispin]
#360948
12/10/03 03:29 AM
Depends on what you want to end up with. If you want to build a better set of headers, start by using mandrel bends instead of simply bending straight pipe with a bender. Want to make further improvements? Use stainless steel -- 304 is probably good enough for normally aspirated motors. Want more? How about some quality collectors. I'm partial to Burns' Stainless' collectors, like these 3-to-1's: http://www.burnsstainless.com/MergeCollectors/3into1base/3into1base.htmlBut really, there's a lot more to good headers than just some bent pipe and a good merge collector. The header needs to be tuned to match the engine's powerband and intended operating rpm. A skilled welder can make a set of headers from the right set of parts, but a good header builder can extract a lot more power from the same materials by getting the length and diameter of the pipe "just right". It's part science and part experience. Of course, if you just want a set of headers that's built to higher standards, quality mandrel bends and a pair of good merge collectors is a great way to start. Jeff
Re: DIY headers?
[Re: tkrispin]
#360949
12/10/03 04:23 AM
We use to buy 90, 45, 180 bends, straight tube, 3/8ths plate for the flanges, and a set of gaskets to use as templates and we would make them for the street rods. It was quite involved with a lot of cutting, drilling, hand fileing on the flanges, fitting, welding, and a whole lot of cussing and beer drinking!!! Then companies started makeing them at a reasonable price and they were tuned, so we would buy them.:D
"Serenity through Sobriety"
Re: DIY headers?
[Re: OOP'S]
#360950
12/10/03 04:29 AM
LCE sells a make ur own kit
john
Re: DIY headers?
#360951
12/10/03 04:56 AM
LCE sells a make ur own kit john 4cylinder, he is looking for 3.0 V-6!!!!!! <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: DIY headers?
[Re: OOP'S]
#360952
12/10/03 05:13 AM
Anybody tried the ones for the 3.4 or are the ports different?
Re: DIY headers?
[Re: tkrispin]
#360953
12/10/03 03:41 PM
Sure you can do it. Summit and many other speed businesses sell piping for this. Hardest part is doing the flange at the cylinder head.
Smooth and long. Keep that in mind and you'll probably make an absolutely dandy header.
'97 T-100 SR5 '86 Toyota's, the variety pack (all gone)
Re: DIY headers?
[Re: tkrispin]
#360954
12/10/03 06:52 PM
It would be very cool if you tried this. I've often thought of it myself.
I wouldn't sweat the whold power band thing, I mean the aftermarket headers change that as it is. It's a just a matter if you like the change. I personally wouldn't mind some more top end out of my 3.0. I think worst case you'd have to shorten or lenthen tubes.
Idea: Maybe you can mock up some headers with clamps so that you can swap out straight sections. Try a few configurations so see what you like best. Then weld it up? Then let is know the final dimensions. <img src="/forums/images/graemlins/smile.gif" alt="" />
Frank.
1994 4runner, 3.0, auto, 4.88's, 31's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos. www.sdori.com
Re: DIY headers?
[Re: elripster]
#360955
12/11/03 03:36 PM
Cool, thanks for the responses. Once I get a garage, a welder, bender, etc etc... then I'll start making headers! <img src="/forums/images/graemlins/smile.gif" alt="" /> Until then I'll just keep thinking about it...
